turn one power steering pump pressure choice
since money is no good unless you spend it, i think i'm going to mail order a turn one power steering pump. it's for a 2002 ss that's summer daily driver. any advice on the pressure choice other than the standard 1500 psi?
thanks,
http://www.turnone-steering.com/#!on...egory=12405744
thanks,
I just did a bunch of research when I had to replace my PS pump (I went with a stock AC Delco pump). If you're a daily driver with lots of around town / low speed turning you'll probably want the stock rebuild option from turn one. Anything with lower pressure and you could notice increased steering effort for low speed turning. Since turn one can rebuild to anything you want I'd give them a call and they can point you in the right direction for your specific needs.
They did not even ask me, nor offer ANY options as far as system pressure goes, when I ordered mine about 3 years ago.
I am guessing they just gave me the 1500 psi pump since I did tell them I autocross/road race the Z28??
When I bought mine last year I didn't get a choice on pressure either.
zfastss makes a good point though, low rpm turning with a Turn One pump is pretty tough...parking lots are a bit of a pain in the *** for me. Good workout though
looking it up in my 2002 service manual, for LS1 it states 2.7 to 3.1 gallons per minute and 1200/1300 psi for pressure for the power steering pump.
For v6 losers the pressure is the same but gpm is 2.4 to 2.8.
so you guys are saying that you ordered a turn one pump and did not request a different pressure setting than the default given, and you have difficulty in low rpm turning?
Save the manuals!
thanks,
thanks,
I sent them my pump and they did a stock (kept original pressure) rebuild for me. (I do daily city driving and wanted to keep the extra stock assist that you loose with the racing version.) The other plus is that they put their pulley on for me (this really needs to be done in their shop) and the pump is now really easy to move out of the way for alternator changes, etc.
now i'm a little confused.
the oem pump is 1200-1300 psi according to my gm service manual. the turn one pump website says theirs is 1500 psi unless something different is requested.
I would think that the default turn one pump @ 1500 psi would be stronger and the wheel would be easier to turn at idle rpm? This would be the turn one pump using my existing oem pulley taken off my oem pump.
so, is the turn one pulley a different size then (smaller?) compared to the oem pulley size? and if so, does it cause you to use a different serpentine belt size?
i know i said money is no good unless spent, but that was thinking i didn't need to spend an extra $80 for the turn one pulley... which is also on back order currently.
Save the manuals!
http://www.superchevy.com/how-to/060...-pump-install/
^ BTW - This article is old and I believe they are referencing the old LT1.
If you couple the ease of installation with the fact that the stock pulley doesn't fit normal pullers very well, the $80 is money well spent if you are going to keep the car a long time. IMO - It became "worth it" the minute I needed to unbolt the thing to move it out of the way for Alternator surgery.
BTW; besides the pulley being keyed, it is also racing wire tied at the end to make sure that it does not come flying off in case it ever does loosen on the shaft IF you have them install it (some racing orgs actually require this to be done).
