Removed AIR Now HVAC Does Not Switch
Removed the AIR! setup on my '01 TA. Followed previous threads and deleted all the items needed. Situation now is when I adjust the HVAC controls for foot/head/defrost it will not change. It is stuck on head or straight. I know that the system operates via vacuum so for troubleshooting purposes I removed the cap from back of the intake and ran a connector to the hose in the harness. Attached picture for reference. Suggestions?
LS1Tech Premium Sponsor
Check the and make sure the vacuum line on the back of the intake is hooked up because that will effect the A/C controls.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Currently not by the car but if you trace the small vacuum hose through the harness it goes to somewhere in the headlight/overflow/front fender area. Is there a canister of some sort which holds vcauum? Also if you look at the picture posted the vacuum lines connect to a union fitting which is white at one end. Is that a one way valve?
