Does removing the plastic air dam in front of the radiator effect cooling?
I recently put a tubular front bumper support on my car and was curious if removing the plastic air dam in front of the radiator would have any effect on coolant temps. I assume since all that foam that was blocking the holes in the bumper is now gone, that more air would be able to get to the radiator/trans cooler along with whatever air comes from under the car. Has anyone removed that front air dam and if so did you notice any change in temperature?
LS1Tech Administrator
Received 1,467 Likes
In stock form, this air dam is necessary because these cars don't have a functional grille. If you have an open grille now that is able to flow air to the radiator, then in theory you should be able to remove the air dam without much concern.
My question was that since I no longer have that bulky front support would the holes in the bumper become functional and increase air flow to the radiator. That air dam blocks the air path through the holes to the radiator.
How does the air damn block the radiator, the air dam is behind where the radiator air flow is located therefore forcing air up into the area infront and above of the air damn where the radiator air flows I still don't exactly see your reasoning for removing it.
IF one converts to a 'front breather' vs. a 'bottom breather', and eliminates that plastic spoiler under the car without adding a full NASCAR style air dam to the bottom of the bumper, or a substantial splitter under there, then YES, the high speed stability/handling would be very negatively effected by lift.
Its part of the cooling system and the air coming up from that lower air dam is directed back into the condensor because of that black plastic piece. Without it....a lot of ram air will get lost by coming up into the engine compartment.
