Off-throttle squealing
I have been getting a strange squealing when I let of the throttle. It sounds almost exactly like a brake pad indicator squeal but happens without applying the brakes. It only happens right after I let off the throttle and the sound "pulses" instead of being constant. Any ideas?
Moderator
Received 1,835 Likes
The classic wheel bearing diagnosis is that it is worst on the outer wheel when making a turn or changing lanes. Slalom the car a bit with the windows down at 40-ish mph. When you veer right, you should hear the left wheel, etc.
I had a squeaky pulse noise off the front wheel that turned out to be loose center caps. Check for that also
Difference in driving most likely ... I am on the highway 80% of the miles on it.
Moderator
If turning or changing lanes makes no difference, your bearings are OK. If you've already checked your center caps, sounds like the rear brake indicator might be all it is.
If the throttle makes a difference, it could be as simple as the exhaust noise covering it up.
One other thought is that e-brake horseshoe inside the rear rotors might need replacing.
