HELP: window hotwire kit
Sorry to make ANOTHER window motor. Ive used the search method and am either getting very confusing wiring diagrams or the ones with photos are so outdated they're no longer showing. I've been using this (below) wiring diagram
Relay Number 1:
30 – To Window Motor Brown Wire
85 – Chassis Ground
86 – To Window Switch Brown Wire
87 – Battery +12 Volts
87a – Chassis Ground
Relay Number 2:
30 – To Window Motor Blue Wire
85 – Chassis Ground
86 – To Window Switch Blue Wire
My question is, on Relay #1 pin 86. There are 2 dark brown wires and one tanish wire running into the window switch. Which of these wires am I supposed to cut and splice? Thanks for any and all info!!Everything else is wired according to above except this very last splice! PLEASE HELP!!
Relay Number 1:
85 – Chassis Ground
Relay Number 2:
85 – Chassis Ground
