Lost drive belt, now car is over heating v6
I lost my drive belt yesterday right by autozone so I went in and got a new one and popped it on and went on my way, only to find out that after maybe 3 miles, white smoke starts bellowing out from under the hood and my temp. Gauge jumps to 280.
So I stop, wait for it to cool down then get up to speed and then turned the car off and coasted home. I start to fill the radiator with water and I notice that is coming out just as fast as I'm putting it in, and the leak seems like it's coming right under the upper intake plenum. Any ideas guys?
Something had to have caused the belt to be thrown.
Did you check your water pump? Is it locked up? Leaking from there?
Heater hoses come out the side, off the tensioner assembly (yeah, a bit weird). There are plastic elbows that go into the block on the other end. Are those still intact? Not uncommon for the plastic to get brittle and break.
which v6? on the 3.8 the water pump is about 6-8 inches directly below the throttle body upper intake and the pouring out of fluid sounds much like what happened to me on my dads old Suburban when the water pump blew out, for me it happened right as I parked the car so I never overheated.
http://youtu.be/g6mivXV6gRU
I had one of the plastic elbows suffer catastrophic failure on the highway, in my '04 Bonneville. It's amazing how fast the car can dump two and a half gallons of fluid under pressure, at 70 MPH. Definitely replace with the aluminum version.
