where to get power window motors for 2001 fbody
Also don't just buy the cheapest ones you can get, BUY the DORMAN ones.
Oh and blackandgold, those "lifetime" warranties typically only cover 1 replacement of each part for free.
I am 3 years and 4 months since I replaced my passenger window motor (which had previously been replaced 2 years prior to that by the previous owner)
Save the manuals!
Unfortunately, we have re-entered a dark time for replacement motors on our cars...
A few years back, a manufacturer popped up and started making a much improved NEW design of the window motor. We have not seen any horror stories of these failing but they seem to have disappeared from the market.
Originally, they were marketed under the Duralast brand. Then they were picked up by Dorman and underwent a much wider distribution. However, in the last year it looks like Dorman dumped the new design and went back to the old design, made in China. (with new content)
The jury is still out on if these "new" Dorman old design motors are any good, but I wouldn't bet the farm on it. Until we can find the source of the new design motors, they are probably the best option out there. Buying from somewhere offering a lifetime warranty is probably wise advise here.
These wiring kits are pure snake oil. They may add longevity to a bad and dying motor, but the don't fix anything and they certainly won't give a motor infinite life. Throwing money at this kind of thing while putting a new motor in is a total waste. (People rave at how they "work" wonderfully - but they just put in a new motor at the same time!)
This thread has some more information on the mythology around these kits and some pictures of the latest Dorman motor option:
https://ls1tech.com/forums/pontiac-f...hs-truths.html
I've read the myths thread, but the thing is, a voltage drop can damage a motor. It will cause the crappy resistor to heat up more. Granted I never actually looked at the threshold of our window motors, maybe even with the voltage drop they can see everything is still within spec.
Electric Motors and Voltage drop
FWIW: I've never installed one of the new wiring kits and prefer to just warranty mine out as they fail. But if the drop in voltage in our cars is below the required spec for the motor it will cause an increase in heat which will damage resistors in the motor.
Save the manuals!
The majority of the people rolling in the aisles over the wiring kit miracle are too lazy to even check for the mythical problem they are trying to "solve." It's a lot easier (I guess.) to replace the motor, plunk down another $100 for the wiring kit, stare at the heavens, raise ones arms, scream "Halleluiah," and claim that they have been saved.
The new motor design, which is now MIA, was the elegant solution to the problem. We are just (unfortunately) very short on information as to who the real manufacturer was/is. (we know the last two companies who marketed it) Hopefully another marketer/retailer will pick it back up again soon.
I read through both threads and didn't see the actual voltage reading and what the spec is for the motor in either...
I'm not going to sit here and blindly make claims because frankly I don't know what those measurements are myself.
TLDR: Yes a voltage drop can damage an electric motor. No I do not know if the drop on our cars is outside the motors spec.
Save the manuals!
That is the kind of thing we need to be careful in doing - especially on a site devoted to Tech discussion. The manufacturer of those kits doesn't even make such claims. (We also have people here calling them a "fix" and the manufacturers don't say that, either.)
It's in other threads. If anyone cares, they can search or go measure for themselves.
But, you did blindly make a claim when you said that if the OP purchased a wiring kit then they would never need to change their motor again.
Advance Auto has remanufactured window motors for $55 with a lifetime warrenty as long as you have the car.
