Quick question for the A/C guys
Getting ready to swap out my A/C condensor and it arrived today. I noticed the new Ac Delco condensor is not plugged. Is this going to be a problem? Everything I have read says to keep everything plugged up to avoid moisture.
yes it should have came plugged. when working on any ac system commercial, residential, car ac it should always be pinched off and brazed closed or plugged. basically it will acquire moisture and contaminents from the air. Im Not to familiar with car ac but as long as u can pull a very good vacuum below 500 microns u will be ok.
Im not sure if it was pre serviced. Think I'm just gonna return it and check the dealership for one. Also does anyone know if the Murray brand from orielys or the Autozone equivalent are any good?
I have a Murray. It works ok, but I don't expect more than a year or two out of them. $190 for the Murray is nice compared to the $450 for the Delco. But the Delco should last better than a decade vs the year or two I typically get from a Murray.
Honestly, id run it. I realize thats not the most correct way but I highly doubt it would be an issue. Accumulators or driers are sealed in bags when you buy them, most other ac items are not in my experience.
how do you know some idiot didn't repaint a used one and sell it as new, or return it to a store and the store doesn't know any better?
having ac parts like the condenser or accumlator plugged before you get them is not critical. as long as the part is packaged decently in a box and is clean and dry that's what matters. when you pull vacuum on the ac system with the new parts installed that is what will take care of any moisture and when you'll find out if the parts are good when the system holds a deep vacuum. if your new condenser has any corrosion on it, or chipping paint near the tube ends, looks like it's been handled or has or any oil or other kind of stuff inside the tube then consider returning it as defective/damaged.
