Built LS1 engine noise. Lifter? Clutch? Headers? AC drive?
Old 10-01-2015, 09:30 PM
flyjum's Avatar
Default Built LS1 engine noise. Lifter? Clutch? Headers? AC drive?
Watched a ton of youtube videos and none really sound like this.
I am leaning towards a header leak but not sure.
I was told the car would need a new clutch and that is what the sound is.
Recent maintenance is new AC compressor new plugs/wires and a tune.
Under car sound
Engine bay/warm sound
Old 10-02-2015, 07:43 AM
gagliano7's Avatar
I just went through a similar noise and it ended up being a header gasket leak at the head on the bottom side . I actually found it when I pulled my new spark plugs and found 2 that had a black tint on them. I thought for sure I had a lifter problem.
Old 10-02-2015, 07:55 AM
svede1212's Avatar
This is my sure-fire way to diagnose exhaust leaks easily and without burning yourself. I plugged off one pipe and pressurized the other to 15# or so. You'll find any leak quickly.
Old 10-02-2015, 08:13 AM
pattyfirefire's Avatar
Willing to bank on headers 😟
Old 11-26-2015, 09:54 PM
flyjum's Avatar
Forgot to update this
It was a prop shaft bolt that came out of one of the couplers
It was the rear coupler but the bolt rattled to the front. I guess what ever shop installed the billet couplers used the wrong locktite
Old 11-26-2015, 10:10 PM
jenfred10's Avatar
Prop shaft bolt to coupler.....not sure I'm following?
Old 11-27-2015, 05:43 PM
dailydriver's Avatar
^^^It's a C5.
Quick Reply: Built LS1 engine noise. Lifter? Clutch? Headers? AC drive?
