What does this elec. harness plug to?
Car is a 2001 Formula. Can anyone tell me? Located in front of the shifter. It's not the 12v socket or the cig. Lighter. It is the one with a pink/fushia, gray, white, brown w/ white strip and black wires going to it. Thanks
Save the manuals!
There are extra harness connectors in there, which may not be used depending on how your car is equipped and if it has traction control or is a convertible. If I remember correctly, that's the one for the traction control switch.
Ok thanks. Do you know where the switch is? Or where this plugs into? I don't think i have tcs since there is no button or whatever. I can't seem to find it. Thanks.
Save the manuals!
You probably have a little cubby hole built in to the center panel that fits in above the gear selector. Cars with TCS or convertibles don't have that cubby. Instead, they have a switch panel in that place, (the storage cup snaps out and the panel snaps in its place) which is where the TCS and convertible top switches go.
