Battery Connectors
Battery Connectors
This is probably a stupid question but it comes down to the point that Ive never had to replace one of these. The negative battery post connector's bolt is rounded to the point where I cant really secure it. Once in awhile my voltage gauge drops to the red and hangs around there for a minute or two and springs back to life and I am almost certain that this is the reason because I haven't had this issue until I had to mess with the battery. It COULD be the alternator too, but its fairly new and a Duracrap Gold - well..thats not saying much, anyway...
I'd still like to replace the connector. Is it possible to do this without replacing the whole cable? If so, how do you pull the connector part that holds the bolt head out without damaging the cable?
The bolt will come out if you pull it with some sort of pliers to help punch it out, shouldn't take to much effort. Any auto parts store will carry it, it's just a 3/8 bolt terminal. Check you voltage running it should be getting a steady 13.5+ volts at the battery with the engine on if the alternator is doing it's job.
