Help troubleshoot 2 problems (High idle & starts on 3rd attempt)
99 Camaro SS T56, low 130K miles. Been down for about 5.5 years. New racetronix fuel pump with hotwire kit, cleaned fuel tank, new fuel filter, 93 octane from a top tier station, red ford injectors, stock tb (ported). NGK TR55 plugs are new, MSD wires have at most 28K miles on them, coil packs are stock, harness is stock, big 4 upgrade and new battery
1. My tuner says my Idle air control may be bad because my car dies (forgets idle floor) when you throw it in neutral as you are approaching a stop light/sign. However, if you blip the throttle after you put it in neutral, the RPMs stop falling at about 1K RPM and the car acts normally. Is there any way I can test it to be sure before I spend the money on a new part?
2. Also, this has happened to my car twice. The first and second time that you attempt to start it, it just cranks and cranks. One the third attempt, it starts. The pump primes every time. I check fuel pressure at the schrader valve on stock fuel rail and the car has fuel pressure. How much? I dont know. Whats a fuel pressure gauge with good bang for the buck ratio cost? metco mff0001 and mfp0001? https://www.nastyperformance.com/sho...chrader-valve/
any help would be greatly appreciated
thank you
thank you
Check fuel pump pressure. I had to replace my racetronix with a new one last year.
My car has had a high idle for years, I have tried everything including a new IAC and have not been able to resolve the issue. I suspect mine is a vacuum leak. If you change your HVAC settings from floor, to off, to defrost etc does the idle change at all
It should go up 150rpm if you have ac on.
how do you check fuel pressure? throw a gauge on the end of my stock fuel rail with a tool like the one in the link below?
http://www.harborfreight.com/fuel-in...ter-92699.html
the car does not want to start now.
i rented a fuel pressure gauge from o'reillys and this is the result. can anyone tell me if my fuel system is functioning as designed or not? this is my first time to use a fuel pressure gauge. my fuel system consists of the racetronix pump and harness, as well as the red ford 30 pound injectors, which i believe are like 36 pounds @ GM fuel pressure. the car is tuned and should be calibrated for the larger injectors. keyword there is should be. so just to make sure, i am seeing 20 pounds when the fuel pump primes, 60 when cranking the engine and 48 when i stop cranking the engine. I am not throwing any DTCs.
so i replaced the Idle air control. the problem where the car dies when you push the clutch in as you are approaching a stop sign or stop light has improved but is not eliminated. there are situations where the car acts properly, there are situations where the car wants to die but does not actually die and there are situations where the car actually dies.
is there anything else to check besides the tune? I dont have any codes on the dash.
thank you
thank you
Moderator
Received 1,835 Likes
Did the ign relay replacement correct the fuel pressure?
Should get 58 at prime, stay there after prime for a bit, and hold 55 or so at idle.
the ign relay replacement corrected the issue of the car not starting, but that is about it.
