Key not going into the lock position
I just bought a 2001 Camaro SS and I'm having troubles with the key/lock cylinder. The key will not go all the way into the lock position, and the key can be removed while the car is running. The car can also be started without the key in the ignition. Do I need a new key and lock cylinder or just a new key? This is a big compromise to the safety, it could be easily stolen if i forget to lock the doors. Please help!
Sounds like your lock cylinder is shot, also sounds like your VATS has already been bypassed. Your best bet would to find a used cylinder and to re-enable your VATS which would mean getting the correct resistance key for your VATS from a key vendor then getting a local locksmith to cut the key the same as the one from your new cylinder.
I wouldn't re-enable the VATS if its already bypassed if it were me. Just get a key cylinder and key combo and have them skip out on programming the VATS pellet on the key. You can even order the keys without the pill. I recently did this. If you're interested, I have a good column and key combo.
Okay I figured it all out thank you guys, I found a company that will send a precut key and cylinder with a VATS chip to match my current for $70. and I read that I have to test my key with an OHMS meter.
