P0140 & P1416 codes cause car not to start? 1998 TA
I had my car stall out and is stuck in a parking lot. It has these two codes and won't start. From what I've read, cleaning the check valves and checking for leaks in the AIR hoses. The other seems to deal with the secondary O2 sensor. Both are easy fixes, but the car is stalled and I can't get it home. Would these cause it not to start?
P1416 Secondary Air Injection (AIR) System Bank 2
P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
Drivers' side is Bank 1. Passenger side is bank 2,
LS1Tech Administrator
Received 1,489 Likes
It might be that neither of these codes are related to the actual issue. What happens when you try to start the engine? Does it crank at all? Does it sputter at all? Do you hear the fuel pump prime? Have you checked fuel pressure? Have you checked for spark?
