mystery squeak
mystery squeak
hey guys,
recently my 2002 ss has started making a squeak specifically under acceleration under about 15%-20% throttle input. the squeak sounds like its coming from the the throttle linkage on the firewall in the car, however, I've sprayed everything with wd - 40 and the squeak comes back after about 5 minutes.
any suggestions?
thanks!
any suggestions?
thanks!
Save the manuals!
What is "everything"? Does the pitch of the squeak change with the speed of the car? The RPM of the engine? Can you make it happen when the car isn't moving? Are you saying the noise only happens when the accelerator pedal moves?
Everything means the hinge on the pedal, the hinge bolted to the firewall and the throttle cable that is visible inside the car when u fully depress the pedal. The noise doesn't change pitch at all and is not related to rpm
You can also unhook both ends of the throttle cable, spray some of the lithium grease inside the tubing from under the hood, and work the cable back and forth.
If you feel and major dragging, or 'snapping', it could be a sign that the cable is starting to fray inside.
Save the manuals!
I'd avoid this cable if at all possible. It isn't intended to be self-serviced. (A motorcycle cable specialist is probably the best place to get it rebuilt and properly lubed.) I got some water in a clutch cable once and it was pure hell when it froze.
