Weird Noises?????
Weird Noises?????
so guys i need some advice.... my car has a grinding/poppingish noise coming from the rear end or trans i think... its not a new noise. its been there since ive had the car. its only on initial throttle, or i can hold the brake and between 1800-2000k rpm it does it, i can mash it down the interstate and it wont do it.... any ideas of where i should start looking?
Do you ever get a clunk going from drive to reverse?
You can pry at the joint between the joint and the driveshaft and watch for play. There should be no play.
Yup...bring it to a drivetrain shop if the u-joint needs to be replaced. My shop in Lauderdale that I use charges $25.00. Well worth it to have it done right.
But check that torque arm bushing for dry-rot or if its falling apart. Or any play in it. It only has to move a tiny bit to cause issues.
