Rear sway bar bushings were the culprit (squeaking)
For those that still have their original rear sway bars and rubber bushings I'd just like to pass on some info if you have squeaking/rubbing type noises that you can easily hear at low speeds, especially going over bumps in the road. My mechanic located the irritating noises as coming from the rubber bushings. It seems like a relatively easy job for you 'do it yourselfers' and not expensive either (the AC/Delco were $25 for both).
Remove two bolts from each bracket holding the bushing and replace. You definitely need to have the car on a lift or high enough to work on as the new bushings require some strength to slip over the sway bar as it is tight (there is a slit in each bushing). My mechanic suggested no lube or grease should be used. My noises are now long gone.
** Many parts houses have the wrong size listed and the first two parts we ordered were for the front sway bar only. Make sure you specify rear when ordering so you don't have aggravation like we did.
Hope this helps someone out there, and just returning the favor for so many helpful things I have learned from this section over the years.
I'm getting ready to replace the bushings soon as well due to the same noise issues. Assuming you have the 19mm rear sway, what is the AC Delco part number for the bushings? What are the part numbers to avoid?
Thanks
Thanks
I apologize but I don't have the part numbers. I didn't think to take the box home with me and I don't have it written down anywhere. I'll post again if my receipt says anything. I haven't paid yet so I need to get it from the shop. One of those 'stop by and pay me later' relationships. I may go this afternoon.
LS1Tech Administrator
Received 1,492 Likes
Thanks for the post Dave. I've noticed a similar type of sound coming from the rear of my '98 in cool weather, especially when I pull in and out of a driveway or such. I assumed it was the rear lower control arm bushings, but perhaps it might be the rear sway bar bushings as well or instead. I just noticed it this year, so I haven't bothered to mess with it yet. This gives me another area to check.
BTW, non-1LE V8 models received a 19mm bar, and the 1LE cars received a 21mm rear bar. I have a set of 1LE bushings that I ordered from SLP about 15 years ago when they began offering the 1LE package which GM had dropped after '99. They don't have any part numbers stamped on them, but I'm not sure if they used GM as the supplier for this item.
Thanks, it's been a chore trying to find the part number. I found the bushing on ebay, did it include 2 bushings or just 1?
I might go with the greasable poly bushings as I heard the swaybars do not articulate like a control arm and thus poly is fine. Thanks for the Permatex suggestion, is it safe for rubber/poly?
Also the end links cause a lot of noise. If you're getting "creaking" sounds, especially going over speed bumps, this is likely your problem.
I went with Prothane end links and their bushings. Quiet as a mouse now.
