LS1 TB coolant line coupler
Old 10-15-2016, 07:31 PM
JimMueller's Avatar
Default LS1 TB coolant line coupler
It appears I've developed a bit of a coolant leak at the coupler. I've always thought the two hoses with a coupler was a bit of a hack, is there a better solution?
Old 10-15-2016, 10:01 PM
Mumbles's Avatar
Unless you're driving your car in cold weather, the Throttle Body Coolant Line is completely unnecessary. I would recommend bypassing it.
When I've bypassed the TB Coolant line in the past I simply used a single hose with two clamps. No leaks here.
Old 10-15-2016, 11:34 PM
JimMueller's Avatar
It's been bypassed for well over a decade, that's why I'm using a coupler. Is there a reliable solution to run a single hose instead of using a coupler? Or is the only solution still the combination of a 5/16" heater hose & a 1/4" heater hose?
Old 10-16-2016, 04:30 AM
LS6427's Avatar
Get the combination coupler....thats the proper way to do it. It will last forever. Mine is like 10 years old and still perfect.
Old 10-16-2016, 06:44 AM
JimMueller's Avatar
PN and/or link?
Old 10-16-2016, 06:51 AM
LS6427's Avatar
Originally Posted by JimMueller
PN and/or link?
I went to PepBoys and looked through their hardware drawers and found a coupler. Bought two smaller worm clamps and that was it. No idea what the part number was. It was a brass piece and each end had ribs so the rubber hose when pushed on was almost impossible to come off. Almost didn't need clamps, but of course I used them.
Old 10-16-2016, 07:21 AM
Mumbles's Avatar
I suppose the 2 different size hoses with a coupler is the correct way to do this. But, I'd like to point out that the more connections you have, the more chances you have to develope a leak.
A single 5/16" Hose with 2 Clamps has worked fine on the half dozen cars I've done this to.
I'm not trying to convince you either way. Just want to point out my experiences. Good luck.
Old 10-16-2016, 08:09 AM
LS6427's Avatar
As long as the clamps are good, anything will work. But two different sized hoses clamped to a pipe thats only one size...is more of a weak point then to have the proper combination pipe with the correct sized hoses and strong clamps. Also, when you buy the combo pipe it has graduated barbs on it...as you push the hose ends on its gets tighter and tighter and clamps are almost not needed. And again....I would always use clamps.....just saying how amazingly tight it gets with the barbed ends.
Old 10-16-2016, 11:09 AM
JimMueller's Avatar
So I'm still using a 5/16" heater hose connected to one end of this ribbed brass coupler, and a 1/4" hose from the other end of the coupler to the cylinder head nipple, with hose clamps at each junction, correct?
This is the only thing I could find locally, will this be fine for a coupler? Although historically I only run water Water Wetter with distilled water, I've read that glycol makes fuel line brittle, and I also don't know whether the bulk fuel line is rated for coolant temp and pressure.
https://www.summitracing.com/parts/r...FUovgQodXrMP1w
Old 10-16-2016, 04:17 PM
LS6427's Avatar
Thats what mine looks like, except its got the 5/16th and 1/4" ends.....they are out there, keep looking. PepBoys has them here in South Florida.
Quick Reply: LS1 TB coolant line coupler
