TPS Screwed Up Again
Had a problem last year... turned out to be the ABS module shorting out the 5V lead causing it to be over 6V.
Well a new problem has emerged. Tried 3 different TPS sensors (two new ones both read much higher than the OE - including the ACDelco one, so I don't know what's up).
But I've tried both a NW 102 and a FAST 102 TB. FAST closes down tighter so I can get voltage to .45V with the OE TPS. NW is around .55V all the way closed down.
Issue is I see 1% TPS all the time even with a TPS relearn. And at those voltages.
So I decided to test... 5V lead sees 5.05V when grounded to battery. The ground lead sees about 11.88V when grounded to the battery. Both within spec. The PCM lead however shows 6.6V when grounded to the battery? Isn't that supposed to show between .4 and 4.9 or so? Granted, I didn't have it hooked up to the TPS when I did the test, what's the free air value supposed to be? If that all checks out and it's doing it with all my sensors, do I just need to rewrite all when I flash the PCM?
I cleared all codes. Did TPS relearn multiple times...
Other symptoms were I'd drive for 30 mins. Everything was fine. And suddenly when I came to a stop I'd be reading .72 or .81V or something and 4% throttle. When just a few mins before I was at .57V and 0% throttle. I checked the NW TB and it looked like the shaft may have moved on me. So I was going to try my FAST TB but can't get a reset to 0%.
Hep.
Hep.
One other thing, when I scan in HPT, I can watch the TPS voltage. And it's smooth. With the NW it was .55V closed and 4.39V open.
It was driving fine until yesterday. But it had been having the 4% TPS after a 30 min drive regularly. I would just TPS reset and it'd be fine to drive. Even when hot that same day.
Should I go with the ACDelco sensor that reads higher? Let me try that. TPS sensor might just be fucked. But the TPS signal reading 6V is also crap.
Save the manuals!
Are you measuring the supply voltage and ground with the connector off? You'll get odd voltages otherwise. The only thing that I'd expect you could reliably probe with the connector hooked up would be the signal wire.
You have an aftermarket throttle body, right? Have you tried taking the sensor off and seeing what your scanner shows when you turn it by hand?
Yeah. Aftermarket TB. Switched back to the FAST. I have both a FAST and NW. Both have their pros and cons. lol
New ACDelco sensor and FAST it seems to be okay. For now. Reading .55V. And the blade is cracked open a bit. The NW was loose and the blade stop was changing on me. So I was also chasing that. The FAST is much stiffer.
The issue is the FAST IAC passage is too small.
Did you ever figure this out? I'm having a code P0122 and all the voltages seem to check out
Grey 5.03 volts
Blue 0.6 volts (closed) 4.5 volts (WOT)
Black 0.033 volts
One weird thing and I don't know if this is normal, opening the throttle until it hits 2 volts, at 2 volts the multimeter will read "OL" for a split second and go back to normal. I posted a video of opening the throttle.
My thread
https://ls1tech.com/forums/general-m...ing-p0122.html
Grey 5.03 volts
Black 0.033 volts
My thread
