Question about start up procedure after storage
I stored my 2000 Trans Am one year ago and I'm about to get it running again. Before I stored it I did the following:
1. Removed Battery
2. Filled up tank with fuel and additive for storage.
3. Put the car on stands, supporting the suspension not the chassis.
4. Polished, waxed and used cover for interiors.
5. Kept in garage.
6. Changed engine oil with synthetic type.
7. Added some anti-moisture stuff in the cabin.
8. Removed carpets
Now I will drive it for 15 days, but then will store it again for another year! So far I know I will need: a fresh battery, engine oil and coolant.
My question is if I should add the new coolant and oil right after I turn it back on again or wait until I'm about to store it again?
Anything else I'm missing or that I should do before turning it on?
Thanks,
1. Removed Battery
5. Kept in garage.
8. Removed carpets
Thanks,
LS1Tech Administrator
Received 1,486 Likes
If you changed the oil immediately before storage (meaning no miles or significant engine run time on the oil), why would you change it again right after pulling it out of storage? Fresh oil sitting in an engine with zero usage is still perfectly usable one year later - especially synthetic and even more so when stored indoors and not exposed to rapid temp swings.
If it's due for a coolant change then you might as well do that sooner rather than later; this will give you time to get the level proper and bleed any air out of the system prior to putting it back in storage.
Sounds like you did great storage prep last time, I would suggest doing the same after the 15 day driving period.
With proper additive (which the OP said he used) and storing the tank full (less air = less moisture), 12 months is a non-issue. Mine has spent most of it's life on fuel that's between 6-18 months old - no problems at all following the aforementioned routine (even with our local E10 fuel.)
Get as much of that old fuel out as you can over the 2 weeks. Siphon out whatever is left is needed. Unless you're coolant is 5 years old (assuming DexCool) I wouldn't change it unless a test strip or voltage tells you it's lost significant potency. The green coolant might only be good for a few years. Your synthetic oil might be good for 5-10 yrs, especially in a dry/warm climate. I've seen UOA's on little used cars like yours and the oil showed nearly full potency after 5 years. If you're going to waste a new battery every year get a $49 one from Walmart. It might even be covered under warranty each year.
You won't need a new battery every year if it's disconnected while in storage. It might need a charge, but if it was fresh (or will be a new one this year) it won't be junk in just one year of disconnected non-use. My Nova sits for ~6 months every winter with the battery disconnected and voltage is still 12.4x-12.5x in the spring. It wouldn't be discharged to the point of permanent damage in another 6 months.
Thanks for your answers, I did change the oil right before storing it. I didn't know if it would be ok after one year of sitting there, I had no idea it could be good even after 5 years of storage, It's my first time storing a car.
I do intend to drive it a lot and will most likely burn all the fuel in the tank so I can add fresh one when I store it again.
The battery was at least 1 year old when I took it out, maybe 2. I'll check if it's still good to work with a charge or not.
The coolant was just a few months old, so based on what you're saying it should still be in good shape, but I'll check it anyway.
Think about boats. To store a boat for winter you fill the tank, add stabil, change the oil, fog it, pull the battery, then your done. Next summer you have to at least burn all of the old fuel, then the following fall rinse and repeat. People do this year after year and no damage, especially up north where boating season is only 2 months. No need to replace the battery if you had it at full charge when you pulled it. If you let it sit at weak charge for a couple years it's toast.
