Battery age?
Battery age?
Can anyone tell me how old the battery is? It's been in my '04 GMC truck a long time and still works fine, but I am replacing it anyway.
Thanks, Frank
Thanks, Frank
Save the manuals!
It's either May of 2004 or May of 2014. The laws of physics would seem to indicate the later date but:
- That label looks a lot older than 2014
- I'm pretty sure no one has made commodity/conventional lead acid batteries in the US or Canada for a while.
Could it be the original battery? When in 2004 did your car roll off the assembly line? (You should be able to figure that out by the door sticker.)
LS1Tech Administrator
Received 1,486 Likes
Hard as it may be to believe, that looks like an assembly line label. The labels used on post-assembly, parts counter AC Delco batteries are substantially different (and have been prior to even 2004.)
FWIW, I've noticed that the Group 78 sized batteries, like yours, tend to be more durable and have longer lifespan than some other models (such as the smaller Group 75 in the F-bodies.)
Thanks wssix99. My suspicions and curiosity is the same. I bought the truck a couple years old and have never replaced it. It still works fine. I have now replaced it with a Delco. I wonder what I should do with it - it does deserve a place of honor somewhere.
Save the manuals!
Maybe you could clean up the case/label with some rubbing alcohol and put a battery tender on it every year for a decade. At that some collector may drop a pretty penny for a factory battery that still runs?
^ Maybe RPM would know if such a market exists?
I may keep it around tho I am trying very hard not to be such a parts collector anymore.
I considered replacing it last winter and the winter before but it showed no signs of weakness. The truck behaves no differently with the new [800amp] battery ... I am listening and it seems to turn over cold with the same ooomph . I thought it might spin faster or something.
Pontiacerator
I learned my lesson with old batteries some years ago. I kept having strange electrical issues on my 69 GTO with voltage regulators burning up, flickering lights, ignition modules getting fried (had to put the old points back in) and IIRC, (possibly unrelated) alternator failures.
The battery always cranked the starter over just fine, seemed to have plenty of power ... before I finally discovered it had an internal short. Replaced it and all those other issues went away.
So the moral of the story is ... don't trust an old battery even if it turns the starter over admirably.
this would be related to the capacitance of the battery, as in capacitor not capacity. and a capacitance test can be done but it takes somewhat expensive equipment to do it right... typically more than the cost of the battery so you just replace the battery in most cases.
https://www.motor.com/magazine-summa...tery-of-tests/
Batteries provide an additional less-well-known function of absorbing or dampening transient voltage spikes. This ability is called capacitance. Insufficient battery capacitance can cause perplexing driveability issues. Most of these result from excessive AC ripple current in the charging system, although a few are traceable to insufficient voltage spike dampening, usually originating in the ignition circuit.
Pontiacerator
this would be related to the capacitance of the battery, as in capacitor not capacity. and a capacitance test can be done but it takes somewhat expensive equipment to do it right... typically more than the cost of the battery so you just replace the battery in most cases. https://www.motor.com/magazine-summa...tery-of-tests/
