Advance/Autozone parts return?
My car has a extremely frustrating issue of dying randomly on idle. I was going to purchase a Throttle positioning sensor to see if that solved the problem and was wondering what everyone's experience is regarding returning parts? From what Ive read most of them state 'in new condition' but if I install the part and it doesn't immediately fit the problem, I obviously don't want to keep it.
If the item isnt in a blister pack, how the hell are they going to know anyway?
Your car doesn't throw any codes or anything, it just dies? Does it stumble then die or what?
Autozone, Advance, etc don't allow returns on used electronic parts. Once you've installed it, it's yours. Now if they can't see that from the packaging or the condition of the part, that's a different story.
I've done it just to weed out items as the problem.
Just have to tell them one thing, its what I've said to them for 18 years with my Trans Am.
"The guy that owned the car before me modded it and it uses a totally different part, I wasn't able to install it."
Blister pack or not....you took it out and it would not line up with anything because its been modded.....
Just keep it clean......or clean it....before returning it. There is no way they can tell if you have installed it....as long as its perfectly clean. I've done it countless times. I've even driven around a couple days with parts that I returned this way.
There's nothing wrong with the part....you just hooked it up to see if it was causing the problem. Why buy parts and throw money away trying to find the problem...that can cost you $1,000 and still not fix the problem.
You're not screwing anyone over....they still have a brand new part with a 1 year warranty.
I would look to Crank Shaft Position sensor or maybe Cam Shaft Position sensor. These parts, when failing, will not always give you a code.
Pain in the ***.....
I'm in the automotive parts business and I won't take an electrical part as a return, only exchange. I've been doing it long enough to look at the terminals to know if it's been installed. The problem I explain, is that if you have a wiring issue in your car, it could possibly cause the new parts to fail, thus creating an issue for the next customer if they return it.
Yeah it is most likely the poor fitment of the TPS to the 92mm Ebay throttlebody I got when I bought a used Fast intake. However, what makes me want to try a new TPS is the issue of the car falling on its face at 6k RPM during dyno runs and a guy stating he had the exact same problem and replacing the TPS solved the issue. For a 40$ part, its definitely worth the try but if this doesn't resolve the issue I don't want to **** away 40$.
i own:
- PDF copy of the 93 fbody service manual
- Hard copy of the 93 service manual.
- hard copy of the Chilton repair manual
Local Autozones here will take ANYTHING back broken busted whatever. I was having blower motor problems burning up the controller. After they replacing 3 motors and 2 burnt up controllers I asked them what if it burns out again? They told no problem just bring it back and they will either replace or give me money back MY CHOICE needless to say I buy Autozone from now on.
Now Advance I had a bunch of trouble with their radiators AND their return policy. I bought new rad and after suffering for 5 effin hrs putting it in it leaked.....................ok pull it back out and realize it effin junk. Some of the crimps were not even crimped some missing in spots I told them I want a refund. NOWAY they said only replacement.......... SOOOO Advance gets me a replacement....same sheeettt NO GOOD. I had to contact a regional manager to get a refund so I could go buy a well made radiator at Autozone that doesn't leak and is well crimped. EFF Advance, bunch of morons work there. They tried to convince ME<a advanced engineering dood that not all the crimps on a rad get crimped and a little leakage is normal.
I was born at night, BUTT not last night.
GO TO AUTOZONE, good bunch of gals and guys in there that try their best to help.
