98 camaro window maintenance driver side
i was wondering if anyone could tell me the name of the part that goes behind the t-bar inside the door. (its attached to the glass track i believe)
Save the manuals!
This is a common failure of the channel that is riveted to the bottom of the window glass. Check out the links in this thread: https://ls1tech.com/forums/general-m...ller-size.html
The roller is riveted to that bracket and it slides in the vertical track. The rivet has ripped out of the bracket (picture 2).
I had this issue 2 times, on an LT1 and LS1 car. I found a steel patio door roller at Home Depot, that was basically the same size, not identical, but close enough, to the OEM roller. I used a bolt & 2 nuts, I forget the exact size, but it is short. And solved the issue, both times.
