Solved!! Better window motors 3rd,4th gen - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 02-20-2017, 07:26 AM   #21
silverformula's Avatar
Quote:
Originally Posted by wssix99 View Post
In the interest of fair and open transparency...
Neither of you guys let your cars be touched by water that falls from the sky, right?
#MostCarsLiveARoughLife
Quote:
Originally Posted by RPM WS6 View Post
You're thinking of my '98 car. It's not even allowed to see humidity. The motors on that one are original and quite fast (almost shockingly so), but I didn't think it was a fair example as the car is most definitely a garage queen. On the other hand...
I was thinking the same thing, could it be moisture or humidity or heat, etc. that causes to the inner part of the door to flex and that is why the motor gets out of aliment and wears out faster?
By the way, my window motors are original but I only have 31K miles on her.
silverformula is offline   Reply With Quote
Old 02-20-2017, 08:27 AM   #22
The earliest Ive ever had mine go bad was at about 90k miles
Need4Camaro is offline   Reply With Quote
Old 02-20-2017, 08:44 AM   #23
I'm interested on hearing what Need4Camaro and Lup and everyone has to say about the inner parts of the door flexing with age.
Old 02-20-2017, 01:04 PM   #24
chrysler kid's Avatar
The doors are fiberglass, I've seen fbody door skins crack away from the frame, happens from time to time. If yours is flexing the bonding glue is probably starting to come apart
chrysler kid is offline   Reply With Quote
Old 02-21-2017, 03:04 PM   #25
My car is my only car....for the past 19 years. It sees rain almost every day in South Florida summers.....gets dirty all the time. Have to wash it 2 times a week.
LS6427 is offline   Reply With Quote
Old 02-21-2017, 03:06 PM   #26
Damn....my 1998 has at about 225,000 miles....at least......
Old 02-21-2017, 10:02 PM   #27
Pontiacerator
RevGTO's Avatar
I replaced my driver's side with a Cardone about 10-12 years ago and it's still working fine. My passenger side is slow and sometimes I have to raise it a section at a time, but it's still alive on this 17 year old car. The moral of the story is ... exotic engineering exercises really aren't necessary to deal with this issue. If it quits, spend $25-30, fix it and enjoy
RevGTO is offline   Reply With Quote
Old 02-22-2017, 07:18 AM   #28
Save the manuals!
wssix99's Avatar
Quote:
This happened to me with every stock motor I ever installed. It annoyed me to no end and I would have paid handsomely to fix it.
The "new" motors out of the box even did this. I'd pay extra to not have to install the motors over and over and over and over again!
wssix99 is online now   Reply With Quote
Old 02-22-2017, 01:11 PM   #29
LS1Tech Administrator
RPM WS6's Avatar
I'm surprised you had that type of trouble with new motors right out of the box. The old-style Dorman I installed on mine, plus a couple Siemens and other old-style Dormans I've installed on other 4th gens never had a problem when new. I only kept mine for about 2-3 years after installing the new motor, and I'm not in touch with the new owner, so I don't know its current status. But the others I've installed or helped to install have held up well for the most part. Definitely never had issues with any right out of the box like that.
In my experience, tinting paper seems to accelerate the failure rate of original or replacement OE motors....greater drag perhaps? Or maybe it's because those folks are constantly rolling their windows down to avoid tickets as they pass by cops?
RPM WS6 is offline   Reply With Quote
Old 02-24-2017, 12:21 AM   #30
Pontiacerator
RevGTO's Avatar
I'm getting old and lazy about working on cars. When my first motor failed I learned about the procedure and charged into the job with gusto. I gladly did it on both my sons' cars. Now the idea of doing this job is about as appealing as the prospect of spending several hours in a dental chair.
Old 02-24-2017, 04:58 AM   #31
To each their own. Note though that while the thermal resistor by-pass works as a permanent fix on the stock motors, it does not increase their speed any faster than their brand new condition speed where as this mod also increases the speed by a pretty noticeable amount and that's the real reason why I did this.. I wanted overall faster motors.
Old 02-26-2017, 12:28 AM   #32
Here's my 2 cents worth, after owning many power window 4th gens and always fighting this issue and now owning a manual window 4th gen I will never by another power window equipped fbody. The manual windows work 1000x better than the garbage power windows.
MY_2K_Z is offline   Reply With Quote
Old 02-26-2017, 02:18 AM   #33
RPM WS6's Avatar
Quote:
I wish it was easier to find ones with manual windows. I wouldn't mind at all, my '71 has all its original (manual) window components - they've been working fine for 46 years.
Old 02-26-2017, 10:20 AM   #34
Save the manuals!
wssix99's Avatar
You guys must also prefer to crank start your cars?
Old 02-26-2017, 11:14 AM   #35
I know it seems odd. But once you own one you will see my point t of view.
Old 02-27-2017, 01:28 PM   #36
My first F-Body was a blue 98 V6 and it had rollup windows. For the reliability, not too bad..but for reaching over to the passenger side to roll it up once it starts raining, I can pass.
Related Topics
Thread Thread Starter Forum Replies Last Post
2005 Silverado RCSB Trick Turbo 4WD, 4L80e lxcoupe Vehicle Classifieds 4 03-20-2017 07:23 PM
Ls parts gmcyukon Parts Classifieds 7 02-20-2017 10:11 AM
Window Regulator Fix Majozak Paint & Body Work 3 02-15-2017 08:52 AM
Solid 1" rear swaybar for 4th gen fbody Photochop Parts Classifieds 0 02-13-2017 08:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
