Car not starting
Car not starting
I have a question about my 2002 WS6. A couple of weeks ago, I cleaned the engine with a cleaner and rinsed it with water. It didn't want to start when I was done, so I took my air compressor and blew the rest of the water away from the motor. After I did that, my car started. I put it back in the garage and went out a couple of days later. Now it doesn't want to start. I don't know if I got something wet that I shouldn't have or what I did. I had the battery checked, it's good. It cranks, just doesn't turn over. Any ideas to help get her started would be appreciated. Thanks
Super Hulk Smash
Hey I moved this to maintenance as it may get more response here.
When you say you washed it, did you soak the entire engine? If you got the starter wet it may have shorted out. But I doubt it. But it does sound electrical.
Had you got water past the manifold into the motor, it would crank and hydrolock and boom. So I don't think it's that either.
I checked all the fuses. I haven't pulled the starter yet. It's been too cold here lately. I may have to do that when the weather gets warmer.
Those are the same....NO....?
Do you mean the starter is spinning and the crankshaft is turning?
If the engine internals are spinning.......I would crank it while someone else grabs the wire bundle that is coming directly out of the PCM and see if it starts.
Update to my original message.....Battery and starter both checked out good. I don't have any fuel in the fuel rail when I depress the valve. I sprayed ether in the intake, car started. I let it run for about 10 minutes or so. I shut it off and tried to restart, nothing. Checked the valve on the fuel rail again. Nothing came out. I don't know why it ran fine for 10 minutes or so then on the restart nothing. Is it possible to not have power to the injectors? I'm lost for right now. I can hear the fuel pump kick on when I turn the key, so I know it's not that either. Thanks for the help
Thank you so much Chrysler kid, it was the ignition relay. I swapped it out with the fan relay and it started right up. Thanks again, made me happy to hear my car run again.
I'm glad I haven't had that problem. Now I'm going to check my fan relays because my car was getting abnormally hot on a couple cruises I went on last year. Thanks again
