P0336 code help asap!! crankshaft position sensor - LS1TECH
Thread Tools Search this Thread
Old 03-16-2017, 02:18 PM   #1
Default P0336 code help asap!! crankshaft position sensor
i have code P0336 doesn't happen all the time maybe once every 100 miles it starts to sputter and shake and runs bad then when I hit the brakes it jerks forward a little. Got it checked and it's the crankshaft position sensor I replaced it 6 months back because the car woudnt even start but now it's throwing the code again what can it be all answers will be greatly appreciated thanks in advance!!
5.7z28 is offline   Reply With Quote
Old 03-17-2017, 06:08 AM   #2
What causes the P0336 code?
•The reluctor wheel has broken, snapped, or has worn down teeth
•Crankshaft position sensor magnet shavings have gotten stuck on the sensor or the reluctor wheel
•Wires and circuits have burned or shorted out
•A short in the crankshaft position sensor wiring harness
•A broken or corroded crankshaft position sensor connector
•Engine misfire(s)
•Faulty crankshaft position sensor
•Faulty camshaft position sensor
•Faulty ECM
RockinWs6 is offline   Reply With Quote
Old 03-17-2017, 01:46 PM   #3
chrysler kid's Avatar
Check your transmission fluid level. Make sure it isn't low on fluid and your torque converter isn't causing extra drag (sounds like your car is automatic)
Also check your engine ground cables to make sure they are tight and clean. Typically a crank sensor failure is similar to a fuel pump failure and the car will not start or run
It is also possible you may need to perform a crank re learn procedure on the new crank sensor
chrysler kid is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
