Rear clunking sound and vibration
I have a 94 z28 with a t56 and I recently replaced the opti. That front of the car was on jack stands for about 4-5 weeks. Now whenever I drive the car, I have this bad vibration. Almost like a wobble vibration that kind of correlates with speed. There is a fast intermittent clunking sound that comes from the passenger rear area too. I'm not sure as to what is causing this vibration and sound. Any help would be greatly appreciated! Thanks!
With the age of the vehicle make sure that the rear torque arm bolts are tight at the housing and that the LCA and PHB are not warn out. Also make sure the tires do not need to be balanced.
Moderator
Received 1,835 Likes
Check your calipers and pads too
