replacement door handles dorman or plastic
my 94 door handles are fairly loose and make a lot of noise. I thought it was bushings, but they were fine. It's the handle itself. looks like just worn out and not a serviceable part.
So I ordered a dorman steel version for the driver side $23/amazon and 9/ebay for the passenger side that is plastic. Let's see how the quality is.
This guy has it well documented.
https://ls1tech.com/forums/general-m...or-handle.html
i would check and see if you can find the pin somewhere. i was not able to.
Thanks. On mine, the right side of the handle seems well-located, but the left side (still driver's door) of it is all loose. So much so, that the paint has rubbed off on the top from contacting the door handle pocket.
I assume that either the pin is missing, or the left nut on the inside of the door is loose/gone. I played with the handle a while back, and I remember it feeling like there was no hinge pin on the left side, so I'm assuming it is missing the metal pin. The door was replaced before I bought the car, and they did a terrible job of it, so it has been this way for around a decade-and-a-half. I will check again soon. I have to get some manual pedals from a pick-your-part anyway, so I will see if I can yank a handle pin while I am at it. Those door handles are on freaking everything GM made since the 1970s.
Seems I was mistaken. I checked today, and the pin is still there. It is actually the right side of the driver's handle which is loose. The hinge pin may just have some wear, making it smaller than it should be. Oddly, I do not see where the handle is touching the top of the pocket when I open it, but it could be farther back than I can see. The back piece seems tightly affixed to the door. Maybe the wear occurred before being transferred to the new door?
