Bent Fenders after Oil Change
Old 11-10-2004, 08:20 PM
SS3933's Avatar
Default Bent Fenders after Oil Change
I'm sure someone has encountered this. I took my car into work to day (dealership) and had the oil changed. I didn't notice it until I got home that the bottoms of both fenders have been pushed out about 3/4" of an inch from the rest of the body. It's caused by jacking the car using the fender tabs underneath the car. Before I go to the service manager tomorrow does anyone know if this is just a simple matter of hammering the "now" bent tabs back into place or is there more to it than that?
Thanks
Old 11-10-2004, 08:38 PM
2001FireBird's Avatar
Yeah my homeboy did the same **** when I placed Eibach springs on my car. He didn't know you were suppose to place them on the chassis points. It wasn't that bad I guess, but it did **** me off. I just gently used a hammer and pounded it little by little back into place. Looks fine now, but there's a little play on it. But other than that you could fix it easy.
Old 11-11-2004, 01:19 AM
LANDONZ's Avatar
Take some pliers and grip it and pry it inword..thats what i did for mine!
Old 11-11-2004, 08:07 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Mine got bent at a body shop, but luckily the fenders weren't affected in any way. Why anyone would think that that little bracket would support the weight of the car is beyond me....
Old 11-11-2004, 11:50 AM
NOBR8KSS's Avatar
One side on mine completely broke off... on the other side I used a 3lb hammer and a 2x4 to bend it back into place. It worked fine, but the broken side had to be replaced. It took me 3 months to get the shop to pay for it.
Old 11-11-2004, 02:36 PM
01 Red WS6's Avatar
Mine are bent but my fenders are fine. I want to fix it but just havent had time yet
Old 11-11-2004, 03:34 PM
tuffluck's Avatar
jeez, someone jacked up the car in the wrong spot, huh? someone did that to one side of my car also. the pliar trick works fine. if you actually take out the screw that holds the fender to the underside of the car, you can get a better grip on the metal to bend it back more properly. then you can just screw the fender right back into place after that. it's a common problem; gm didn't engineer those fenders in the most "don't jack your car up here" kind of way.
Old 11-11-2004, 03:52 PM
01 Red WS6's Avatar
I wish I could take the bolt out but it is bent in a way that I cant get it out. Ill get around to it one of these days.
Old 11-12-2004, 10:47 AM
405pathfinders's Avatar
Default Don't wait too long
Same thing happened to me. I fixed it the same way as everyone else.... 2x4 and hammer. However, I wouldn't put it off for too long as I found that dust/dirt build up within the door joints when the fender is out that far. I don't know exactly why....mabye it causes a low pressure area and sucks the dirt in or something but either way it made my door sound awful until I cleaned it out real good.
Old 11-12-2004, 11:42 AM
Chop-Foo Director
PendragonZ's Avatar
Hey guys, be careful using a hammer on this piece. I had the fender treatment on my car (gotta love buying used ) and tried the hammer method. Broke the plastic around one of the bolts. Best to use some pliers to persuade it back into place. Use a cloth in the pliers if you're worried about scratching anything.
Old 11-12-2004, 12:18 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Here's what you do:
Items needed:
1 - Rubber Mallet
1 - Sledgehammer
1 - 2x4, probably about 18" long or so
First, take the 2x4 and place it against the tab, and gently "persuade" the tab back into place with the rubber mallet. Next, take the sledgehammer and put it in your car. Drive to the dealership. Use said hammer to break the moron's toes that thought they could jack the car up by that point. I've had it happen twice, and they haven't found the bodies yet
Old 11-16-2004, 07:36 PM
SS3933's Avatar
Service manager himself fixed it but but broke a small peice around one of the bolts. Gonna start changing my own oil. Sometimes you just can't win. Other than the small broken peice the fenders look perfectly fine again.
Old 11-16-2004, 08:03 PM
Roarin_8's Avatar
I noticed that also on mine, just on one side. Tightened up the screws, not as bad before so I'll use the plier method to finish it up.
Old 11-16-2004, 08:34 PM
WhiteDeathLS1's Avatar
Originally Posted by MeentSS02
Here's what you do:
Items needed:
1 - Rubber Mallet
1 - Sledgehammer
I particularly like this quick fix.
Old 11-17-2004, 05:22 AM
EviLS1's Avatar
Wouldn't they use a lift at a dealership? That's ridiculous IMO
Old 11-17-2004, 09:02 AM
Oscar Will's Avatar
They would use a lift at a dealership but your standard post type hoist with arms/pads has to be properly positioned on an F-body or you'll tweak the front fenders EVERY time. That's one of the first things we go over with new employees.
Old 11-21-2004, 05:56 PM
Shirt_Ripper's Avatar
One more thing. After bending the fender tabs out and then back youre bound to cause some of the paint to come off, so you want to make sure you cover the damage with paint or undercoating.
Old 11-21-2004, 06:31 PM
Moderator
davered00ss's Avatar
Use some vice grips or your hands and bend them back in. i would take it back to them and make them fix it.
Old 11-21-2004, 07:09 PM
Zach@Texas-Speed's Avatar
if someone doesnt know the proper place to jack up the car....they have NO buisness working on one
Quick Reply: Bent Fenders after Oil Change
