LT1/LT4 and LS1/LS6 F-Body Part Numbers
Old 06-15-2005, 01:28 AM
ACW
ACW's Avatar
Default Lights
Camaro headlamp (98-02), LH = 16525313
Camaro headlamp (98-02), RH = 16525314
Firebird headlamp opening doors (93-97), RH = 10138580
Firebird headlamp opening doors (93-97), LH = 10138581
Firebird headlamp opening doors (98-02), RH = 10273622
Firebird headlamp opening doors (98-02), LH = 10273623
Firebird headlamp actuator (motor) (93-97), LH = 16516653
Firebird headlamp actuator (motor) (93-97), RH = 16516654
Firebird headlamp actuator (motor) (98-02), LH = 16524229
Firebird headlamp actuator (motor) (98-02), RH = 16524230
Firebird headlamp opening door actuator control module (98-02) = 16525685
Firebird headlamp bracket clip (for actuator crank?) = 16522437
Firebird headlamp housing panel upper bracket (98-02) = 10247777
Firebird headlamp support (98-02), RH = 10414795
Firebird headlamp support (98-02), LH = 10414796
Firebird headlamp assembly (98-02), RH = 12336000
Firebird headlamp assembly (98-02), LH = 12336001
Camaro fog lamp assembly (93-97), LH = 16519769
Camaro fog lamp assembly (93-97), RH = 16519770
Camaro fog lamp assembly (98-02), RH = 10280985
Camaro fog lamp assembly (98-02), LH = 10280986
Camaro fog lamp bulb (98-02) (AC-Delco #894) = 12450260
Trans Am fog lamp assembly (93-97) = 16514251
Formula fog lamp assembly (98-02) = 10280983
Firebird turn signal / parking lamp (98-02), RH = 10301404
Firebird turn signal / parking lamp (98-02), LH = 10301405
Trans Am turn signal / parking lamp (98-02), socket = 12159662
Trans Am turn signal / parking lamp (98-02), bulb = 9441840
Formula turn signal / parking lamp (98-02) = 10301406
Camaro turn signal / parking lamp (98-02), LH = 5978551
Camaro turn signal / parking lamp (98-02), RH = 5978552
Camaro turn signal / parking lamp (98-02 export - RPO T39), LH = 5978561
Camaro turn signal / parking lamp (98-02 export - RPO T39), RH = 5978562
Firebird taillamp wiring harness (93-02) = 12177554
Firebird taillamp assembly (93-97) (solid red, from V6), LH = 5978019
Firebird taillamp assembly (93-97) (solid red, from V6), RH = 5978020
Firebird taillamp assembly (93-97) (with black grid, from V8), LH = 5978021
Firebird taillamp assembly (93-97) (with black grid, from V8), RH = 5978022
Firebird taillamp assembly (98-02) (honeycomb), RH = 10431948 (formerly 10439148)
Firebird taillamp assembly (98-02) (honeycomb), LH = 10431949 (formerly 10439149)
Camaro taillamp assembly (93-96), LH = 5976011
Camaro taillamp assembly (93-96), RH = 5976012
Camaro taillamp assembly (97-02), LH = 5977791
Camaro taillamp assembly (97-02), RH = 5977792
Camaro export-style taillamp assembly (93-97), LH = 5977819
Camaro export-style taillamp assembly (93-97), RH = 5977820
Camaro SS spoiler third brake light assembly (CHMSL) (98-02) = 12369969
Firebird third brake light assembly (CHMSL) (98-02) = 5977470
Firebird third brake light assembly (CHMSL) (98-02 with T43 spoiler) = 5977471
daytime running lights module (behind radio) (93-02) = 10407669
ACW is offline
Old 06-15-2005, 01:29 AM
ACW
ACW's Avatar
Default Power Steering and Horn
Valvoline Synpower Power Steering Fluid = 1050017
LT1 power steering fluid reservoir (93-97) = 26019594
LT1 power steering fluid reservoir cap (93-97) = 26095323
LT1 power steering pump kit (93-97) = 26040864
LT1 power steering pump pulley (93-97) = 10219382
LS1 power steering fluid reservoir (98-02) = 26068934
LS1 power steering pump kit (98-02) = 26068936
LS1 power steering pump pulley (solid) (98-02) = 12559885
LS1 power steering inlet hose (98-02) (AC-Delco #36P13056) = 26075068
LS1 power steering cooler (98-02 with RPO V12) = 10417037
LS1 steering gear kit (Delco rack and pinion - remanufactured) (98-02) = 26062311
LT1 drive belt tensioner (power steering, alternator, and AC compressor) (93-97) = 12552509
LS1 drive belt tensioner (power steering pump and alternator/generator) (98-02) = 12560344
high note (A) horn (93-97) (AC-Delco #D1925C) = 12368063
low note (F) horn (93-97) (AC-Delco #D1922C) = 12368064
high note (A) horn (98-02) (AC-Delco #D1921C) = 12368061
low note (F) horn (98-02) (AC-Delco #D1920C) = 12368062
ACW is offline
Old 06-15-2005, 01:30 AM
ACW
ACW's Avatar
Default HVAC (Air Conditioning)
air conditioner compressor relay (AC-Delco #15-8571) = 12088567
LT1 AC delete pulley (93-97) = 10115875
LS1 AC accumulator (98-02) = 2724938
AC drive belt = 12569529 (formerly 12559327)
AC refrigerant high pressure sensor (93-02) (AC-Delco #15-5742) = 22664328 (f. 22624066)
AC low pressure cutoff switch (if equipped) (on low pressure side) = 10242579
AC blower motor impeller/fan (93-02) = 52472650
AC blower motor full assembly (93-02) = 52498954 (formerly 52481553)
HVAC vacuum check valve (93-97) = 14056648
check valve to vacuum tank hose = 12124134
check valve to dashboard vacuum hose = 52458911
LS1 AC liquid line (high pressure line to condenser) (98-02) (AC-Delco #15-33164) = 10282758
LS1 AC compressor and condenser hose assembly (98-02) (AC-Delco #15-31009) = 10409630
LS1 AC compressor belt tensioner (98-02) = 12560345
LS1 AC compressor belt idler pulley (98-02) = 12557335
LS1 AC compressor clutch (98-02) (AC-Delco #15-4685) = 6581515
LS1 AC compressor (with clutch) (98-02 LS1) (AC-D #15-20730) = 1137028 (formerly 1137014)
LS1 AC clutch wiring two-way connector (AC-Delco #PT209) = 12101937
LT1 AC compressor (93 LT1) (AC-Delco #15-20048) = 1136490
LT1/L32 AC compressor (94-97 LT1; 93-95 L32) (AC-Delco #15-20178) = 1136535
L36 AC compressor (95-02 L36) (AC-Delco #15-20454) = 1135436 (formerly 1135278)
LS1 AC compressor bolt 1 (98-02) (need 2) = 11516714
LS1 AC compressor bolt 2 (98-02) (need 2) = 11515771
Firebird dash vent, center = 17997681
Firebird dash vent, right = 17997682
Firebird dash vent, left = 17997683
side window defrost vent grille (93-96 Camaro), RH = ? (formerly 17997588)
side window defrost vent grille (93-96 Camaro), LH = ? (formerly 17990492)
side window defrost vent grille (93-02 Firebird, 97-02 Camaro), RH = 10268189
side window defrost vent grille (93-02 Firebird, 97-02 Camaro), LH = 10268190
ACW is offline
ACW
ACW's Avatar
Default Seating and Upholstery
front seat shoulder belt guide (93-96 coupe), graphite, RH = 16730218
front seat shoulder belt guide (93-96 coupe), graphite, LH = 16730219
front seat shoulder belt guide (93-96 coupe), gray, RH = 16730220
front seat shoulder belt guide (93-96 coupe), gray, LH = 16730221
front seat shoulder belt guide (93-96 coupe), beige, RH = 16730222
front seat shoulder belt guide (93-96 coupe), beige, LH = 16730223
front seat shoulder belt guide (96-02 coupe), neutral, RH = 16789714
front seat shoulder belt guide (96-02 coupe), neutral, LH = 16789715
front seat shoulder belt guide (97-99 coupe), gray, RH = 16799272
front seat shoulder belt guide (97-99 coupe), gray, LH = 16799273
front seat shoulder belt guide (97-02 coupe), pewter, RH = 16799274
front seat shoulder belt guide (97-02 coupe), pewter, LH = 16799275
front seat shoulder belt guide (00-02 coupe), ebony, RH = 16817200
front seat shoulder belt guide (00-02 coupe), ebony, LH = 16817201
front seat shoulder belt guide (97-99 convertible), gray, RH = 16799316
front seat shoulder belt guide (97-99 convertible), gray, LH = 16799317
front seat shoulder belt guide (96-02 convertible), neutral, RH = 16799318
front seat shoulder belt guide (96-02 convertible), neutral, LH = 16799319
front seat shoulder belt guide (97-02 convertible), pewter, RH = 16799320
front seat shoulder belt guide (97-02 convertible), pewter, LH = 16799321
front seat shoulder belt guide (00-02 convertible), ebony, RH = 16817202
front seat shoulder belt guide (00-02 convertible), ebony, LH = 16817203
rear seat shoulder belt guides for coupe are only available in whole belt kits
rear seat shoulder belt guide (94-96 convertible), graphite, RH = 10253437
rear seat shoulder belt guide (94-96 convertible), graphite, LH = 10253438
rear seat shoulder belt guide (94-96 convertible), gray, RH = 10253439
rear seat shoulder belt guide (94-96 convertible), gray, LH = 10253440
rear seat shoulder belt guide (94-95 convertible), beige, RH = 10253441
rear seat shoulder belt guide (94-95 convertible), beige, LH = 10253442
rear seat shoulder belt guide (96-02 convertible), neutral, RH = 16789224
rear seat shoulder belt guide (96-02 convertible), neutral, LH = 16789225
rear seat shoulder belt guide (97-99 convertible), gray, RH = 16799280
rear seat shoulder belt guide (97-99 convertible), gray, LH = 16799281
rear seat shoulder belt guide (97-02 convertible), pewter, RH = 16799282
rear seat shoulder belt guide (97-02 convertible), pewter, LH = 16799283
rear seat shoulder belt guide (00-02 convertible), ebony, RH = 16817214
rear seat shoulder belt guide (00-02 convertible), ebony, LH = 16817215
Firebird front belt guide screw (m4.2x1.41x20 hi-low) (93-96 coupe AQ9), LH/RH = 11514301
Firebird front belt guide screw (m4.2x1.41x20 oval hd) (93-96 coupe AR9), LH/RH = 12338093
Firebird front belt guide screw (m4.2x1.41x20 oval hd) (93-96 coupe AX4), LH/RH = 12338093
Camaro front shoulder belt guide screw (m4.2x1.41x16) (93-96 coupe), LH = 16739619
Camaro front shoulder belt guide screw (m4.2x1.41x16) (93-95 coupe), RH = 16739619
Camaro front shoulder belt guide screw (m4.2x1.41x20 oval hd) (96 coupe), RH = 11516665
F-Body front shoulder belt guide screw (m4.2x1.41x20 oval hd) (97-02 coupe), LH = 11516665
F-Body front shoulder belt guide screw (m4.2x1.41x35 oval hd) (97-02 coupe), RH = 11514957
torx screw to hold seat belt clips on rear bench (need 4) = 10138207
Firebird front seat cushion cover, neutral (98-02) = 16813656
Firebird front seat cushion pad (97-02 AQ9) = 16794382
Firebird leather seat headrest cover (97-02), ebony = 16837707
Firebird leather seat headrest cover (97-02), gray = 16796840
Firebird leather seat headrest cover (97-02), white = 16807176
Firebird leather seat headrest cover (97-02), neutral = 16787335
Firebird leather seat headrest cover (97-02), oak = 88898137
Trans Am embroidered headrest (from 99 30th Anniv TA) = 16817951
Trans Am embroidered headrest (from 02 CETA) = 88899197
Trans Am front seat cushion cover (from 99 30th Anniv TA - white leather) = 16811429
Trans Am front seat back cover (99 30th Anniv TA - white leather) = 16811427
Camaro front seat cushion cover (35th Anniv SS - ebony w. gray center, RPO 193) = 88899203
Camaro front seat cushion cover (00-02 AR9), ebony leather = 16837698
Camaro front seat back cover (35th Anniv SS - ebony with gray center, RPO 193) = 88899145
Camaro front seat back cover (00-02 AR9), ebony leather = 16837696
Camaro rear seat cushion cover (35th Anniv SS - ebony w. gray center, RPO 193) = 88899199
Camaro rear seat cushion cover (00-02 AR9), ebony leather = 16840531
Camaro rear seat back cover (35th Anniv SS - ebony with gray center, RPO 193) = 88899188
Camaro rear seat back cover (00-02 AR9), ebony leather = 16840538
rubber boots for front seat mounting bolts = 16718899
Firebird front floor mats (from 97-02 Firebird GT) (graphite, with logo) = 12371048
Firebird front floor mats (from 97-02 Firebird GT) (black, with logo) = 12371049
Firebird front floor mats (from 99 30th Anniv TA) = 12495738
Firebird front floor mats (coupe) (from 02 CETA) = 88892548
Firebird front floor mats (convertible) (from 02 CETA) = 88892549
Firebird t-top cargo mat (from 99 30th Anniv TA) = 10298255
Firebird rear deck mat (from 02 CETA) = 10311534
Camaro rear deck mat (from 35th Anniv SS) = 10311537
t-top headliner (93-02), ebony = 10410050
t-top headliner (93-02), graphite = 12525672
ACW is offline
Old 06-15-2005, 01:32 AM
ACW
ACW's Avatar
Default Controls and Interior Trim
compartment used in place of switch plate for non-TCS coupes (98-99) = 10283438
compartment used in place of switch plate for non-TCS coupes (00-02) = 10411278
switch plate (by lighter), 1 opening (for TCS) (no logo) (98-02) = 10280509
switch plate (by lighter), 1 opening (for TCS) (Pontiac) (98-02) = 10411289
switch plate (by lighter), 1 opening (for convertible top) (no logo) (98-02) = 10280510
switch plate (by lighter), 1 opening (for convertible top) (Pontiac) (98-02) = 10411284
switch plate (by lighter), 2 openings (for TCS and convertible top) (no logo) (98-02) = 10280511
switch plate (by lighter), 2 openings (for TCS and convertible top) (Pontiac) (98-02) = 10411285
switch originally for controlling convertible top (Camaro) (98-02) = 10402721
switch originally for controlling convertible top (Firebird) (98-02) = 10402722
switch originally for TCS (traction control) (98-02) = 10273882
blank foglight switch = 10273932
switch connecter = 12125665
lighter adapter = 12117322
Camaro instrument panel lamp dimmer switch (97-02) (AC-Delco #D1579E) = 12450124
Firebird instrument panel lamp dimmer switch (97-02) (AC-Delco #D1578E) = 12450123
Camaro instrument cluster bezel (the surrounding plastic trim) = 10410608
Camaro instrument cluster with lens (98 LS1) = ? (16232052?) (formerly 16232051)
Camaro instrument cluster with lens (99-02 LS1) = 16211161 (formerly 9380711)
Camaro instrument cluster with lens (99-02 L36 V6) = ? (formerly 9380651)
Firebird instrument cluster bezel (the surrounding plastic trim) = 17997875
Firebird instrument cluster lens (Specmo Enterprises, 1-800-545-7910) = 16230640
Firebird instrument cluster with lens (98 LS1) = 16232042
Firebird instrument cluster with lens (98 L36 V6) = 16232022
Firebird instrument cluster with lens (99-02 LS1) = ? (formerly 9380692)
Firebird instrument cluster with lens (99-02 L36 V6) = ? (formerly 9380652)
Camaro dashboard large top panel (IP upper trim panel) (93-96) = 10267171
Firebird dashboard large top panel (IP upper trim panel) (93-96) = 10274437
F-body dashboard large top panel (IP upper trim panel) (97-99) = 10422746
F-body dashboard large top panel (IP upper trim panel) (00-02) = 10410583
control lever (Turn Signal, Headlamps, Wipers) (with cruise) (US: left side) = 25140743
control lever (Turn Signal, Headlamps, Wipers) (with cruise) (UK: right side) = 25140540
control lever (Turn Signal, Headlamps, Wipers) (no cruise) (US: left side) = 22510733
wiper switch (in steering column, connected to control lever) = 26098535
manual shifter boot retainer ring (97-02) = 10271371
manual shifter boot (comes with retainer ring) (97-02) = 10271369
manual shifter boot (comes with retainer ring) (93-96) = 17997789
Firebird center console trans. shifter opening trim (98-99) (M6 trans - RPO MN6) = 10297905
Firebird center console trans. shifter opening trim (98-99) (M5 trans - RPO M49) = 10297906
Firebird center console trans. shifter opening trim (98-99) (A4 trans - RPO M30) = 10297909
Firebird center console trans. shifter opening trim (00-02) (M6 trans - RPO MM6) = 10413130
Firebird center console trans. shifter opening trim (00-02) (M5 trans - RPO MM5) = 10413132
Firebird center console trans. shifter opening trim (00-02) (A4 trans - RPO M30) = 10413138
Firebird parking brake lever handle (grip portion) (97-99 NP5) = 10291075
center console compartment lid (98-99) = 10273748
center console compartment lid (00-02) = 10421355
cigarette lighter (98-02) = 11516146
replacement for short-handle HVAC/headlight ***** (from 96-98 Grand Am) = 16204959
floor panel deadener = 10249163
ashtray (both auto or manual) (97-99) = 10261420
ashtray, manual trans (00-02) = 10261420
ashtray, auto trans (00-02) = 10421435
ashtray lid/cover, manual trans (97-02) = 10271366
ashtray lid/cover, auto trans (97-02) = 10408634
coin holder = 10245028
hatch release button (under dash) = 10060578
fog light switch (for RPO T37) = 10401243
fog light switch (for RPO T96) = 10273879
TCS/ASR (traction control) switch (RPO NW9) (for near fog light switch) = 10273877
front cup holder trim cover (round) (97-99 Firebird, 97 Camaro) = 10288510
front cup holder trim cover (round) (00-02 Firebird) = 10421365
front cup holder trim cover (round) (98-02 Camaro) = 10281310
front cup holder trim cover (push-in for 12mm square hole) (00-02 Camaro) = 17988488
rear compartment trim retainer (fits 0.25 hole, 1.01 lg, nylon, black) (93-02) = 10121502
armrest (93-02), graphite, RH = 16670348
armrest (93-02), graphite, LH = 16670349
armrest (00-02), ebony, RH = 16638554
armrest (00-02), ebony, LH = 16638555
glove box lamp (12V 2CP lightbulb) (97-02) (AC-Delco #L194) = 9421330
ACW is offline
Old 06-15-2005, 01:34 AM
ACW
ACW's Avatar
Default Security
theft deterrent module (93-95) = 16215659
remote control door lock transmitter (keyfob) (93-95 Firebird) = 12522339
remote control door lock transmitter (keyfob) (94-95 Camaro) = 15725423 (formerly 10239647)
remote control door lock transmitter (keyfob) (without antitheft) (96-98) = 16245103
remote control door lock transmitter (keyfob) (with antitheft - RPO UA6) (96-02) = 16245100
remote control door lock receiver (93-95 Firebird, 94-95 Camaro) = 10273333
body control module (BCM) (keyless entry receiver) (96 Camaro & Firebird) = 16243951
body control module (BCM) (keyless entry receiver) (97-02 Camaro & Firebird) = 9353691
Camaro interior lock **** (93-02) = 10132223
Camaro power door lock switch (94-96), RH = 10402835
Camaro power door lock switch (94-96), LH = 10402836
Firebird power door lock switch (93-02) = 10402843
power door lock (93-02), RH = 16629726
power door lock (93-02), LH = 16629727
manual door lock (93-97), RH = 16629242
manual door lock (93-97), LH = 16629243
manual door lock (98), RH = 16638342
manual door lock (98), LH = 16638343
hatch lock cylinder (93-02) = 12506775
Camaro hatch latch (98-02 coupe) = 16635227
Camaro hatch latch (98-02 convertible) = 16629978
roof lift-off panel (t-top) lock cylinder tumbler (93-02) #1 = 6259309
roof lift-off panel (t-top) lock cylinder tumbler (93-02) #2 = 6259310
roof lift-off panel (t-top) lock cylinder tumbler (93-02) #3 = 6259311
roof lift-off panel (t-top) lock cylinder tumbler (93-02) #4 = 6259312
roof lift-off panel (t-top) lock cylinder tumbler (93-02) #5 = 6259313
ignition key cylinder for manual trans (93-02) (AC-Delco #D1453C) = 26033387
ignition key cylinder for auto trans (93-02) (AC-Delco #D1456C) = 26033390
ignition switch for manual trans (93-96) (AC-Delco #D1405B) = 1990116
ignition switch for auto trans (93-96) (AC-Delco #D1473C) = 26036235
ACW is offline
ACW
ACW's Avatar
Default Suspension
stock F-body front springs (39 N/mm, 223 lbs/in) (93-97 V6) = 22077189
stock F-body front springs (45 N/mm, 257 lbs/in) (98-00 V6) = 22133438
stock F-body front springs (51 N/mm, 292 lbs/in) (93-00 V8) = 22077197
stock F-body front springs (63 N/mm, 360 lb/in) (WS6, 1LE) = 22132887
stock F-body rear springs (16.9 N/mm, 95.4 lbs/in) (93-97 V6) = 22077418
stock F-body rear springs (19.9 N/mm, 114 lbs/in) (93-00 V8, 98-00 V6) = 22077421
stock F-body rear springs (23 to 30 N/mm, 130-170 lbs/in) (WS6, 1LE) = 22132889
stock F-body front shocks (93-97 V6) = 22151319
stock F-body front shocks (98-01 V6) = 22182495
stock F-body front shocks (93-97 V8) = 22140189
stock F-body front shocks (98-01 V8) = 22182498
stock F-body front shocks (1LE DeCarbon) = 22171227
stock F-body front shocks (1LE Koni) = 22140240
stock F-body rear shocks (93-00 V6/V8) = 22182505
stock F-body rear shocks (01 V6/V8) = 10443949
stock F-body rear shocks (WS6) = 22166714
stock F-body rear shocks (1LE DeCarbon) = 22182505
stock F-body rear shocks (1LE Koni) = 22140228
front shock lower bracket nut (hfh, 10x1.5, 6h thd, 21.3 od, 9.8 thk, 13 hex dr) = 10255857
front spring seat (93-02) = 22099275
front strut/shock upper mount (93-02), LH = 22146933
front strut/shock upper mount (93-02), RH = 22146934
front upper control arm cotter pin (93-02) (0.09375x1.5) = 103376
front lower control arm cotter pin (93-02) (0.125x1.250) = 9440095
rear susp. jounce bumper (bumpstop) (long/tapered) (93-97, & 98-02 w. 16" tires) = 10164173
rear susp. jounce bumper (bumpstop) (short/blunt) (98-02 - intended for SS/WS6) = 10282449
rear wheel jounce bumper 15mm spacer kit = 12363935
LS1 front crossmember (k-member) (98-02 coupe) = 10293578
LS1 front crossmember (k-member) (98-02 convertible) = 10438427
LS1 motor mount bolts (to block) (98-02) (m10x1.5x30) (need 8) = 11516328
transmission mount = 22174970
torque arm bushing = 10413903
torque arm mount and bracket, inner = 10252374
torque arm mount and bracket, outer = 10252375
rear anti-sway bar (24 mm) (from 3rd-gen IROC-Zs) = 10035033
Extreme Sport Suspension Package (from 97-02 Firebird GT) = 12363906
front wheel hub bolt (93-02) (4 on each wheel) (m10x1.5x50, 10.9 por) = 11508355
ACW is offline
Old 06-15-2005, 01:35 AM
ACW
ACW's Avatar
Default 1LE Suspension
1LE left upper control arm (93) = 17999419
1LE right upper control arm (93) = 17999420
1LE left lower control arm (93) = 22145389
1LE right lower control arm (93) = 22145390
1LE left upper control arm (94-97) = 22145653
1LE right upper control arm (94-97) = 22145654
1LE left lower control arm (94-97) = 22156435
1LE right lower control arm (94-97) = 22156436
1LE left upper control arm (98-99) = 22156461
1LE right upper control arm (98-99) = 22156462
1LE left lower control arm (98-99) = 52367658
1LE right lower control arm (98-99) = 52367659
1LE front sway bar (32 mm) (93-99) = 26032907
1LE front sway bar bushing (32 mm) (93-99) = 26039956 (formerly 10288551)
1LE rear sway bar (21 mm) (93) = 10021221
1LE rear sway bar bushing (21 mm) (93) = 10235886
1LE rear lower control arm (93-99) = 10164151
1LE rear lower control arm bushings (93) = 10164152
1LE transmission mount (93-99) = 22146231
1LE front springs (LT1, 360 lbs/in) (94-97) = 22132561
1LE rear springs (LT1, 130-170 lbs/in) (94-97) = 22132562
1LE front springs (LS1, 360 lbs/in) (98-99) = 22132887
1LE rear springs (LS1, 130-170 lbs/in) (98-99) = 22132889
1LE front shock absorber (Decarbon) (93, early 94) = 22124758
1LE rear shock absorber (Decarbon) (93, early 94) = 22124790
1LE front shock absorber (Decarbon) (late 94, LJ build code) = 22140190
1LE rear shock absorber (Decarbon) (late 94, 4Z build code) = 22140187
1LE front shock absorber (Koni yellow) (96-99) = 22140240
1LE rear shock absorber (Koni yellow) (96-99) = 22140228
1LE rear shock insulator retainer (98-99) = 22166910
1LE rear shock lower insulator (98-99) = 10009135
1LE rear shock upper insulator (98-99) = 22166909
1LE endlinks = 10221779
1LE rear panhard bar (94-99) = 10262147
ACW is offline
ACW
ACW's Avatar
Default Transmission
M6 input shaft seal (94-02) = 15635337
M6 reverse lockout solenoid (94-02) = 1252300
M6 reverse lockout solenoid seal (o-ring) (94-02) = 12523293
M6 reverse lockout seal (o-ring) (94-02) = 12523301
M6 reverse lockout solenoid pigtail (connector on wiring harness) (94-02) = 12101857
M6 main shaft seal (double lip) (94-02) = 10117848
M6 main shaft seal (triple lip) (94-02) = 12530278
M6 skip shift solenoid (94-02) = 12523292
M6 skip shift solenoid seal (o-ring) (94-02) = 12523293
M6 stock replacement LS1 clutch kit (flywheel, clutch, pressure plate) = 12581650
M6 stock replacement LS6 clutch kit (flywheel, clutch, pressure plate) (from Z06) = 12570806
M6 flywheel bolts (hfh, m11x1.5x23.5, 21 thd, 22 o.d., with sealant) (98-02 LS1) = 12553332
M6 clutch pressure plate bolts (hfh, m10x1.5x25, hdr pt, 17.3 flange) (98-02 LS1) = 12561465
M5 Five-Speed Hurst Shifter (black shaft, white ball, GMPP and 5-speed inserts) = 12371051
bellhousing dowel pins (98-02) = 1453658
bellhousing to gearbox bolt (hfh, m10x1.5x40, 26 thd) (need 4) (98-02 LS1) = 14050422
bellhousing to engine block bolt (98-02 LS1) = 22649722
A4 LS1 torque converter ('Code TMAX') (98-02) = 24210919
A4 LS1 torque converter bolts (98-02) = 11519291
A4 5-pinion reaction carrier gear = 24218069
A4 transmission fluid pan (93-02) = 8667545
A4 transmission fluid pan gasket (93-02) = 8654799
A4 transmission filter kit (filter and pan gasket) (93) = 8657926
A4 transmission filter kit (filter and pan gasket) (94-02) = 24200796
A4 4L60E slightly deeper tranny pan with drain plug (00 Silverado, fits F-bodies) = 24215535
A4 4L60E deep filter for use with deep pan = 24208576
A4 flexplate bolt (m10x1.5x23-g) (need 3) (98-00 LS1) = 12560397
A4 flexplate bolt (m10x1.5x22) (need 3) (01-02 LS1) = 11519291
A4 retainer clips for transmission cooler hard lines (98-02) = 24205103
A4 control lever (shifter) **** (93-99 Camaro with RPO NP5) = 10079809
A4 control lever (shifter) **** (00-02 Camaro with RPO NP5) = 12563173
A4 control lever (shifter) **** (93-99 Camaro with RPO NK3) = 10111639
A4 control lever (shifter) **** (00 Camaro with RPO NK3) = 10163833
A4 control lever (shifter) **** (01-02 Camaro with RPO NK3) = 22680651
A4 control lever (shifter) handle (95-99 Firebird with RPO N36) = 12551597
A4 control lever (shifter) handle (00-02 Firebird with RPO N36) = 12563171
A4 control lever (shifter) handle (95-02 Firebird with RPO NP5) = 12563172
A4 back-up lamp position switch (93-02) (AC-Delco #D2234) = 1994223
A4 neutral safety switch (93-02) (AC-Delco #D2263C) = 24229422
ACW is offline
Old 06-15-2005, 01:36 AM
ACW
ACW's Avatar
Default Rear Axle
10-bolt 3.42 gears = 12471191
10-bolt 3.73 gears (American Axle #26036813) = 14091497
10-bolt 4.10 gears = 26014585
synthetic axle lubricant for 10-bolt rear axle (75W-90, GM Spec 9986115) = 12378261
Limited-Slip Axle Lubricant Additive (4oz needed for full fill) = 1052358
Mobil 1 synthetic gear lubricant (GL-5, 75W-90) = 12345977
differential cover gasket = 26016661
differential oil for Auburn = 12378261
rear axle shaft with traction control = 26059972
Zexel-Torson Torque Sensing Differential (97) = 12363985
Zexel-Torson Torque Sensing Differential (98-00) = 12471371
ACW is offline
Old 06-15-2005, 01:37 AM
ACW
ACW's Avatar
Default Wheels
17x9 Aluminum Firebird GT Wheels kit (from 96 Firehawk/CompTA, 97-00 GT) = 12371050
17x9 Aluminum Firebird GT Wheel (from 96 Firehawk/CompTA, 97-00 GT) = 12366597
17x9x50mm ZR1-style wheels with P275/40ZR-17 Comp TA tires = 12364002
16x8x66mm ZR1-style wheels with P245/50ZR-16 Comp TA tires = 12363998
center caps for Firebird GT wheels = 12366598
jounce bumper spacer kit included in Firebird GT wheels kit = 12363935
blue 17x9 WS6 wheels (from 99 30th Anniv TA) = 9593624
black wheels with polished lip (from 02 CETA) = 9594404
polished aluminum 17x9 WS6 wheels (00) = 9593305
painted 5 spoke SS wheels = 9592881
17x9 SS wheels kit from 35th Anniv Camaro (4 wheels, center caps, lugnuts/caps) = 12498899
17x9 SS wheel from 35th Anniv Camaro (RPO QG4, Black w Machine Polished Face) = 88892486
wheel center caps (from 35th Anniv Camaro) = 9594408
lugnut caps (from 35th Anniv Camaro) = 9595120
WS6 black wheel center caps = 9592700
wheel center caps (from 99 30th Anniv TA) = 9593626
wheel center caps (black with silver bird logo) (from 02 CETA) = 9594405
longer wheel studs (3", not hardened, stock threading, last 1/2" not threaded) = 22551491
wheel spacer = 14091902
lugnut caps = 10028614
spare wheel stowage nut (93-02) = 14071288
ACW is offline
Old 06-15-2005, 01:48 AM
  #32
ACW
ACW's Avatar
Default Documentation
'Corvette Fuel Injection and Electronic Engine Management' book (covers L83, L98, LT1, LT4, LS1, LS6, ZR1 - 1982-2001, ODB1 and ODB2) by Charles O. Probst (ISBN 0-8376-0861-9) = 12497977
LS1 engine kit installation guide (covers LS1 design/development, install notes, engine control schematics, technical info/specs) = 88959384
ACW is offline
Quick Reply: LT1/LT4 and LS1/LS6 F-Body Part Numbers
