want to turn on all parking lights, but without headlights coming up, on 99 TA
how to wire in all parking lights without headlights coming up on 99 TA
I have a 99 TA and I want to be able to turn on the parking lights,but not have the headlights raise up at the same time unitl they are needed. Has someone else done this and could pass on the wiring that needs changed. Thanks
I want to be able to turn on the parking lights and have the headlights stay down until I need them. Has any on done this to their car and be able to tell me what to do to get this done. Thanks
If your headlights are popping up with your just parking lights on that usually indicates a bad headlight motor (one or the other or both..doesn't matter). Do the headlights pop up when your alarm sets..ie: locking the doors or unlocking the doors? Mine are bad and thats what it does. When they are working properly they should only come up when you turn the headlights on...not the parking lights.
Originally Posted by FLA02TA
Hmm intresting. Is it legal to use a brighter set of fog lights and keep the headlights down at night? (if that's even feasable).
i would't try it...just asking for problems and headaches
Headlight=bitch..
If your headlights make a grinding sound it means your plastic gear inside is worn out.. If this happens your lights will not function correctly.. not sure why... but they won't... So if it's making this grinding sound it's not likely you are getting the results you want which is the park lights.
If your motors are working correctly you need to just put your headlight switch in the 2nd position. This will turn on your park light... you can also turn on your fog lights in this postion... If you move to the 3rd position this will engage your motors and your low beam. Your park lights will remain on and your fog lights can toggle on and off. Moving back from 3rd to 2nd will turn off your low beams but leave up motor and parklights... Fogs can be toggled in this postion.. 2nd to 1st will engage you motor (close) & shut off parks.. Fog lights will not work in this position..
But if you have a messed up motor these functions may vary... Also I highly recommend rebuilding your motor over buying new.. You will save alot of money and because of the design of these motors you will have to continue to replace the motors forever until you rebuild one with this kit.
