How to use Seafoam properly?
How to use SEAFOAM?? properly
ok after having a couple issues with my car im gonna do a full tune up and run seafoam thru the fuel system. ive never used the stuff but have heard many people swear by it, what i wanna know what is the proper way to use it, if someone has done it before please lemme know thanks
Most people spray it into the break booster and run it that way, while others put it into their oil and run it then immediately change the oil, others even add it to their gas and run it through that way or spray it directly into their throttle body. The best way I think is going through the break booster but thats just my opinion. Listen to 777 though and follow the directions on the can, thats your best bet.
i use the liquid kind, put it in a bowl, and use the brake booster to sip it out. don't want it to take forever, but don't kill the motor either. you'll need someone else holding some throttle on the car or it will die....unless you're holding the throttle body cam to keep some rpm's up.
you just pull the vaccum hose out of the brake booster...the one that is on the right of it and that connects to the back of the intake manifold (don't disconnect it from the back of your manifold, but rather, pull it out of the gromet on the brake booster). you then just spray it through the tube, and it goes directly into your engine. then you have some concealment from all the smoke...haha
http://camaroz.net/tech/IMG_0485.jpg
You wanna suck it through that vacum line connected to the booster dont pour it in.. just let it sip from it
Edit: sorry for the bigass pic.. thought i had it on 640x480
hmm but that way it wont clean the injectors hmmm i dunno what to do maybe ill do a little of both ill run thru gas like directions say then do a little more thru brake booster
sea foam gets rid of carbon build up and water
ide get 2 cans
and split it up with more going thre the break booster, and then some in the gas tank and the other threw the oil and drive it for about 5 min and change it asap
ide get 2 cans
1 Post
Here's some info straight from the horse's mouth:
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Don't use thatcrap...it has solvents in it. Autorx is a lot better...but it's like $25 a bottle..here's a link http://www.auto-rx.com/
last car i had was a 3S (3000GT vr4) those 3s guys live by sea foam... i used it... worked great... one can into the tank 3/4 sucked through booster line and the last bit was poured into the oil.... ran it for about 4-5 minutes around the block... watched people come outside thinking my car was on fire....it was great fun... then changed oil, plugs etc did a whole tune up actually....it really cleaned it up quite well cause a month later i took my valv covers off and it was actually alot cleaner then it had been before....i got mine at autozone for about $7 a can...if ya do it through the booster break your camera out and dont get scared by the amount of smoke....
I saw the Seafoam site said to use every 2,000 to 5,000 miles for peak performance - this must be for professional racers. I can't see doing it that often..... What's a more realistic mileage for a daily driver?
id guess maybe 30k miles do it usually a good mi mark for major tune up clean up thingys at least for me my friend used seafoam on his little bro's z28 and he didnt change the plugs he just drove the car to cali too from NJ
I say that 2,000 to 5,000 is good for putting it in the fuel tank. I put it through the brake booster once a year in the spring.
I have never put it in the oil, and never will.
Originally Posted by rgaynor85
well ive seen tons of people say seafoam is the shiznit and your the first to say its not thanks for the input but i think ill go with the majority
i didnt go with flowmaster i bought the car with it on there, i woulda bought either magnaflow, or GMMG or true duals. i dont understand why everyone else doesnt say how bad it is for seals everyone says its so amazing and swear by it im sure someone would of had a problem by now and by putting it thru the brake boost what seals is it really seeing goin thru the intake right intot the cylinders and out the exhaust. in the oil i could see it gettin to seals but i sure someone would of said somethin about it killin seals by now if it did
