window motor install
Old 03-28-2006, 04:32 PM
nomadnate's Avatar
Default window motor install
i just put in my window motor using GM's service information online and a guy that use to work at pontiac (i work at a GM dealership) and it was still a major pain in the you know what. Man i am glad it is done though. i got my window motor on ebay for $25 plus shipping. i got out cheap but if i had the money i would totally have taken it to a shop. or at least bought it from a store so i could get all the hardware. Just mainly want to say if you can get this done at a shop I would. Just my opinion. i feel like i have been
Old 03-28-2006, 04:39 PM
pontiac's Avatar
i did not think it was that bad.
Old 03-28-2006, 04:44 PM
L SS 1's Avatar
replacing the window motor was pretty easy for me, if i had to do it again it would probably take me less than 30 min.
Old 03-28-2006, 05:00 PM
2001NBMZ28's Avatar
Wanna help do mine? I'm in Jax and doing it next week using shoebox's directions. J/K I'll have to see how it goes, have the motor, been putting it off for several months.
Old 03-28-2006, 07:09 PM
Fratsit's Avatar
Did you remove the entire Regulator assembly? I just replaced my drivers side an it was not that difficult. Was a pain, but I wont pay someone to do it.
If yuu need to do it again, try this website:
http://shbox.com/page/windowmotor.html
R/
Frat
Old 03-28-2006, 10:35 PM
nomadnate's Avatar
i don't know maybe it was because it was doing it at work and so i had to stop and come back several times. after thinking about it I would probably try it agian. one of my friends has to do it on his 1997 camaro but i think the biggest pain was the rivets.
Old 03-29-2006, 10:49 AM
Fratsit's Avatar
Yeah, the rivets are a pain. The four that are attached to the door are holding the entire regulator/motor assembly in place. If you want to remove just the motor, you need to drill into the door itself to access them.
If you drill the rivets out, I would recommend replacing them with nylon bolts and nuts. I am an idiot and drilled out two of the rivets holding the entire assembly in. Once I realized my mistake, I replaced them with the nylon. Holds just fine.
I have some pictures I can send you via email if you want.
R/
Frat
Old 03-30-2006, 04:45 PM
nomadnate's Avatar
it is already done but thanks though. when i got in there though i realized that it had been done before. the holes were alread drilled in the door and the motor had nuts and bolts already on it. I did remove the whole assembly though as per GM Service Information
Old 03-31-2006, 05:18 AM
Fratsit's Avatar
Cool,
1/2 the battle was done since you have holes already drilled.
R/
Frat
Old 03-31-2006, 05:46 AM
gyrene2003's Avatar
yeah, rivets are a bitch, regulator can be a bitch, but it beat taking it in and getting ***-rapped by a shop!
Old 03-31-2006, 07:32 AM
Fratsit's Avatar
Amen to that!!
One place quoted me $630 for both windows on my '92. I promptly told him
R/
Frat
