problems with lights on a Corvette C5
C5 Maintenence...
So I just bought this 2000 Vette and the following things are wrong:
Reverse lights dont work
E Brake doesnt work
Turn signals crap out
Car is perfect otherwise. The ebrake has resistance, I have to believe the cable is still there, is it tough to get to under the car?
As for the reverse lights, I guess it could be the switch, where does it happen to be located? Also I plan on installing a Hurst Billet plus I have sitting here, would that affect it?
Finally the turn signals just stop working sometimes, if i press the hazard button they come back... sometimes. I guess its the switch or relay behind the hazard button, how do I get to it??
Thanks for the help!!
E Brake doesnt work
Originally Posted by Z28LS1camaroguy
Check all your fuses, Replace E-Brake cable, and change out the bulbs that dont work.
Fuses and bulbs are good..... is the cable hard to get to?
Originally Posted by conan
If the vette is the same as the f body pull the rear rotors off and check the drum pads for the e brake, you might be able to adjust them out if there good. As far as getting under the car do you have a jack or ramps?
Ok, does anyone know anything about my light problems??? thanks
Also I realized my passenger power window is like a few mm too low so I get wind noise, is there any way to adjust it???
