Cruise Control Situation
I need a little help. I do not use the cruise often, so I don't know for sure when the problem happened. However, the only change that I have made to the car is LED tail/brake lights. Due to the low electrical power draw of the LED bulbs, could that keep the cruise from engaging? If that is the case, what can I do to correct the situation? I'm open for suggestions.
Is your car A4 or M6? If it is M6 make sure that the clutch pedal sensor under the dashboard is making contact with the pedal otherwise the cruise control will not work.
