Couple questions guys NEED HELPS!
I have a 2001 z28 42xxx on the clock, some times the car makes a really high pitch whining or squeeling noise some times through out the rpm range mostly at low rpms though, and it sure is anoying, another is when i make a left turn rolling 10 15 20 MPH i hear a (clunk clunk clunk clunk) and that also gets on my nerves, last Question is, i have tooken my car on the freeway a few times and drove maybe 40 50 miles after a while i start hearing a noise like (tick tick tick) sounds like a rod, but i'am sure if it was a rod it would do it all the time? so i'am really confused right now, the car is basically stock just a catback on there let me know guys thanks,
The squeeling noise could be a bad belt, pulley, pully bearings, or even your tensioner.
The clunking noise sounds like your suspension, maybe a tie rod end/ball joint.
The ticking could be caused from injector pulse, I know I can hear mine if I listen for it.
