Clicking noise
Clicking noise
When i rev it up it sounds fine but as soon as the RPMS fall back down i get this clicking noise on the passenger side near my header. Anyone know what this could be?
yeah i have the same problem on mine right now only its on the driverside, and come to find out the Y pipe somehow managed to make its way off the header and thats what the sound was that damn Y pipe is a pain in the ***.
well you do know the walls of the long tube headers are thinner and you more air can go through so you will be able to hear more than the thick stock manifolds, but you could always check your header gaskets to see if thats the culprit.
Start the car in complete darkness - make sure it's not just a plug wire arcing on the header, buddy of mine had a "ticking" noise and it was the plug wire on #6, in the dark we found it right away.
