proper spark plug wire removal technique
No need for the tool. I assume you are taking them out to replace the plugs anywayz. Probably should replace the wires also if its time for the plugs. Just twist by the boot to loosen and pull off. If the wire splits no biggie use needle nose pliers to pull remaining wire on plug and go from there. Have fun and good luck...
I just remember the first time I changed my plugs. Ripped three wires from their boots first time out! Course, I hadn't learned the "twist and pull" method yet, and I thought the boots would come off easy, like they had for every other car I'd owned previously. Learned the hard way that day.
