About to do my window motor
make sure to zip tie the assembly together so the clock spring does not go flying off. Have fun, it is a bitch. It took me about two hours start to finish, then I found the spring came off the regulater, so then add about another 3 to that. BS!!
Make sure you follow the instructions at this link:
Power Window Motor Replacement
There is no reason to remove the entire window regulator mechanism. This link will show you how to do it the easy way. Took me about 1 hr. each side from start to finish.
-Jay-
-Jay-
