organic,metallic or ceramic pads
Old 04-16-2006, 05:55 PM
del3000's Avatar
Default organic,metallic or ceramic pads
My 2000 Ta With Stock Front Rotors Is Vibrating When The Brake Is Applid. I Know It Needs The Rotors Turned And New Pads .are The Stock Rotors Crap(and Replace Them) As I Have Read In Some Of The Other Threads Or Do I Just Turn Them . I Dont Beat On My Car And Have Already Done My Back Brakes . What Is The Better Pad To Put On It . Pros And Cons . Thanx Del
Old 04-17-2006, 08:55 AM
GuitsBoy's Avatar
I dont know if you can get organic pads. Metalic pads will be more gentle on your rotors, but they dust a lot of may squeek. Ceramic pads chew up rotors but they wont squeek.
Old 04-17-2006, 09:15 AM
kazfan30's Avatar
Hey i work at Napa and from what i have seen and have spoken to some Techs at the brake pad manufacturers dont go with ceramic. It does a very poor job of equalizing the heat transfer between pad and rotor. in other words all the heat stays in the rotors..Go with metallic you will be ok. Ceramic is ok, but not for a performance car
Old 04-17-2006, 11:57 AM
Danny2tek's Avatar
I use metallic but its true they do sqeek some
Old 04-17-2006, 01:56 PM
daryl2cb@yahoo.com's Avatar
oem calls for a semi metallic pad. this is your best choice for your rotors.
Old 04-17-2006, 08:52 PM
Pewterpower's Avatar
I use ceramic cuz I hate brake dust and I hate squealing brakes. As far as your rotors go, you can have them turned if they've not been turned before, but I promise you that in 10k miles they will be pulsing again.
Old 04-18-2006, 06:20 PM
zombie1's Avatar
Never heard of an organic pad for f-bodys,but ceramic pads ARE much easier on the rotors. Semi-metallic pads are harder because there is more metal in them than ceramic. Stock honda brake pads can be ceramic on the front and organic on the back, the ceramic pads have aluminum in them, if you look at aftermarket raybestos ceramic they use copper. Different makers use different formulas, some use more metal than others. My car had ceramic on the front when I bought it at 13,000 miles the rears have not been changed yet, just the rotors.Current mileage is 61,xxx. But my hawk front pads are semimetallic and they are chewing the rotors but I don't care because they are close to machine to and I going to replace everything in about a year any-way.
Old 04-18-2006, 06:32 PM
GuitsBoy's Avatar
This is simply not true. For instance, Knife vs. ceramic sharpening stone. Which one wins?
Knife blades and ball bearings are even made of ceramics. All of these things are harder than their steel counterparts, albeit a bit more brittle.
Old 04-18-2006, 07:14 PM
00T\A's Avatar
I use GM pads and The Baer Eradi Speed rotors.
I'am Happy
No dust or sqeeking.
Old 04-19-2006, 12:07 AM
98blackvert's Avatar
i use ceramic pads with little to no dust, no squeeks, and no rotor damage
Old 04-20-2006, 06:58 PM
zombie1's Avatar
Slightly different compostion in those ceramics.
Old 04-20-2006, 07:00 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
me too.
Old 04-20-2006, 07:19 PM
Domestic Demon's Avatar
I'am Happy
Same here.
The stock AC Delco pads are actually excellent quality, they brake well, don't make much dust, don't squeak, and last a damn long time
Quick Reply: organic,metallic or ceramic pads
