check "guages" flashing driving me nutz
Old 04-25-2006, 10:47 AM
hourang's Avatar
Default check "guages" flashing driving me nutz
ok i want this resolved once and for all. my check "guages" light keeps flashing intermittently at idle. it only does it at or near idle. this i believe is causing the car to hesitate at low rpms. when cruising or above idle its fine. what are the causes of a check guages light? i mean does it only go on for oil pressure, voltage, temparature, gas, etc?? or can ignition problems cause this? can you check codes for the check guages? could it be a bad alternator? please help.
Old 04-25-2006, 11:29 AM
11SECSS's Avatar
If your voltage is going low enough during the idle surge then thats poss the problem look at your volt gauge while it doing it.
Old 04-25-2006, 12:03 PM
hourang's Avatar
doesnt budge. my voltage does stay in the 13-13.5 range sometimes, other times its 14+. havent drivin it enough to know the extent of that condition.
Old 04-26-2006, 08:10 AM
hourang's Avatar
no one knows what possible causes for the check guages light is?
Old 05-10-2006, 10:32 AM
hourang's Avatar
WOOT!! i fixed it! it was the wires, put new msd wires in to replace my new $90 autozone wires and bam, runs beautiful no check guages
