left blinker won't turn off by itself after turn
Weird Blinker Problem...
Ever since I installed the new spark plugs, the left blinker won't turn off by itself after I complete the left turn. Right one works normally...what would this be?
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
the bulb may need to be lubed again. [depends when the signal was turned on in relation to the steering wheel..mine don't always turn themselves off either..no car I ever drove did it every time]
The wheel is straight when I pull into the left hand turn lane and after I turn, I notice the damn blinker is still on a mile down the road!
blinker fluid, gee thanks, I'll give that a check.
That is most likely your turn signal switch. There is a cam in your steering column that pushes on the round switch behind your steering wheel. The round switch is plastic and sometimes they break. I've replaced the turn signal switch in my TA and an old 88 buick. My TA's switch would not center properly and caused my right rear tail light to be out. My old Buick had the same symptom you describe. I put a new switch in and fixed it right up. They are a little bit of a pain but not too bad.
