Daytime running lights
Old 05-03-2006, 01:13 PM
LS1BlackBird99's Avatar
Default Daytime running lights
One of my running lights went out on my 99 T/A. How hard are they to change? Anyone got a write up somewhere?
Old 05-03-2006, 01:48 PM
Moderator
nhra-trans-am's Avatar
sick your hand in the opening below the light and the socket is above. twist it and pull it out, then replace the bulb
Old 05-03-2006, 01:54 PM
'01HAWK's Avatar
I got mine from the bottom. There are 3 bolts, 10 mm I think, on a black plastic flap at the bottom. Unbolt, pull flap down and you can reach strait up to the light. Twist socket out and replace bulb. Took less than 5 mins.
Old 05-03-2006, 01:56 PM
Is it a 3157 amber bulb?
Old 05-04-2006, 06:26 PM
Anyone? I can't find the number in a search.
Old 05-04-2006, 06:31 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
as far as i know it is..just put 2 new ones in a week ago..went from below through the trap door...
Old 05-04-2006, 11:35 PM
sscamaroburn02's Avatar
just take out the headlight (one bolt) and go in from the top. it will take you a total of about 5 min max. I've done this like 4 or 5 times.
Old 05-05-2006, 12:12 AM
LT1Powered's Avatar
Don't touch the glass part of the bulb without gloves. the oil from your fingers shortens the life of the bulbs. (atleast everytime i replaced mine without gloves touching the bulb they blew out alot faster then when i would leave the bulb alone)
Old 07-06-2006, 12:27 PM
2000WS6Vert's Avatar
Does anyone know what the replacement part number is for the actual housing? I can see small cracks forming in both of my DRLs and now they leak.
Does anyone know where I can get these at a reasonable price?
Thanks!
Old 07-06-2006, 08:26 PM
Pewterpower's Avatar
ebay.
Old 07-08-2006, 09:13 AM
TORCHD 02 TA's Avatar
you sir are correct
Old 07-08-2006, 02:46 PM
12Gauge's Avatar
Thanks!
Part number is 10301404. I got mine at the dealership for about 35 bucks or so.
