amplified hidden antenna
does anyone know where to find an AM/FM antenna that could be hidden in the rear quarter panel area? It would also require some sort of plug for the hole in the quarter panel where the antenna went through...i looked at o'reilleys today but couldnt find anything.
I just hooked one up inside my 65 elky b/c i shaved the hole in the fender when i painted the car.
Got the antenna at advance auto, it sticks to the inside of the window. They only had 1 kind in stock.
it requires a ground, and power when radio turns on. Seems like it works well so far. I will take some photos and let you know aftern the holiday if you would like
gobble gobble
pics would be great! how would i go about filling the antenna hole on my t/a? i guess is there epoxy that would bond to the fiberglass quarter panel? im not fond of bondo.
Many years ago I installed a hidden amplified antenna (I think it was called "Cateye"... not sure) in my '89 Camaro. I had it wired through the dash, up the driver side A-pillar, and then along the top of the windshield. Worked like a charm and had at least as good reception and the stock antenna. I installed it primarily because the little monsters at the mall started playing this game where they'd run through the parking lot ripping antennas off of cars. Who ever had the most antennas at the end of the night won. Little **** heads. They never got mine though.
Marc
Marc
i just started looking for a smaller antenna cuz i seen one on here that i like. i cant remember where though. but this is the only one that i have found so far.
http://www.autoaccessconnect.com/antennas.html
found a hidden antenna that mounts inside any figerglass or plastic fairing.
http://www.dragspecialties.com/fatbook/5/21/3870817
