Which spark plugs to use???
Hi im about to do a plug change on my 99 trans am and I was wondering which plugs are the best to use. Motor is stock, I was thinking to use the bosch platinum 2's...Which do yall prefer?
Originally Posted by DomesticLS1
They were 200.00 at autozone and I just...
no serioulsy they shouldnt cost more than 80 or 90 bucks at the most perhaps you were looking at something else?
I just put NGK TR-55's in mine this weekend with the MSD 8.5mm wires. It rocks, noticable difference indeed.
FYI, you can order the MSD wires from Summit (www.summitracing.com) that's what I did. $58 and free shipping.
Originally Posted by staringback05
dont do the boschs, go with the ngk tr55s or the ac delco iriduims....the tr55s are about 12 bucks total and the ac delcos are a bit more but are a good plug....dont go with anyother ngks really unless ur spraying or heavily modded
Originally Posted by BigBas83
is there any reason NOT to use Bosch platinum plugs? or is cost the only factor?
T.T.T. I have a question,
I just bought Bosch plugs, just the normal ones not the 2's, 3's or 4's. I bought them because the store ran out of NGK and I had my headers off so the timing was right. I spent like $20 or something on all 8 plugs. Question is, should I keep these? Or get NGK TR55's or NGK Tr6's?
If your just putting on intake and long tubes I would recommend the Delcos. They seem to be really good plugs and they are what came in the engine. The only reason to go with another plug IMO is if you are spraying and need a colder plug or want a hotter plug for some crazy reason. The delco plug is plenty of spark for what you are talking about and they will last a long time. I got 110,000 out of my stock delcos and frankly didn't notice much difference when I changed them.
Originally Posted by dirtyblackhoe
what heat range and gap should you run? I plan on just going with longtubes, true duals, and intake. nothing other then that.
Hey whats the difference betwwen 32819 ans 32079. All i can see in $50.
32819
http://store.summitracing.com/partde...5&autoview=sku
32079
They both have the same specs at the bottom of the page.
32819
32079
