Alarm going off randomly?
Old 05-07-2006, 08:57 PM
The PAT WS6's Avatar
Default Alarm going off randomly?
Ive noticed that my alarm on my car is going off randomly, rather it be a work or at 3 o clock in the morning ( while the car is in the garage) it is sometimes just the two honks and sometimes its the constant honking for several minutes?
what could this be?
thanks
Old 05-07-2006, 09:55 PM
Camaro_Z28's Avatar
Maybe a shock sensor going bad, there is also a sensitivity adjustment on it, Its in the rh rear by the spare. if it is adjsuted too sensitive it will do that. Mine was going off sitting at the track everytime a loud car would drive by in the pits, so I would turn the sensitivity down on it and see if that does the trick.
Old 05-07-2006, 09:58 PM
yeah i have it turned up all the way for purpose, just to be safe, yes and so times it goes off with loud cars and wat not. but why does it go off when theres nothing aroound like at 3 in the mornin???
Old 05-07-2006, 10:16 PM
Camaro_Z28's Avatar
I'd say that sensor is going wack then if she's cranked all the way. I'd visit a junkyard and pull one out of another car, it cant be too much money, that should take car of it I would think. Unless....maybe a stupid ? u didnt turn it the wrong way maybe? If its all the way up, you could sneeze and set it off.
Old 05-08-2006, 08:30 AM
Wyman's Avatar
I just unplugged mine and took it out altogether. Now, no problems.
*Wyman*
Old 05-21-2006, 04:52 AM
MYTFASTSS's Avatar
did it get wet? Did you just have a storm pass in the last couple of days?
Old 05-21-2006, 03:47 PM
LS1obsession's Avatar
During storms my alarm would go off every time lightning would strike close by. It was parked in the garage too. It would go off before the thunder. Now that's f*cked up.
Old 05-21-2006, 08:17 PM
KillerKlown's Avatar
Mine does it to when no one is around and its quiet.......hmmmm
Old 05-22-2006, 02:41 AM
staringback05's Avatar
u could turn it down some
Old 05-22-2006, 07:13 AM
Justin01SS's Avatar
Turn it all the way down or take it out (the shock sensor). I turned my all the way down and it still did it, so it found its way to the garbage. Alarm isnt so effective if it randomly goes off....
