diagnosis help?!?
Old 05-10-2006, 10:44 PM
stanger96's Avatar
Default diagnosis help?!?
i have a buddy with a 95 Z28 with 91k on it....the weirdest noise is coming from it....slowing down to almost stop then punching it once it gets to about ~5k it make this extremely rapid clicking noise(similar to if u take a stick and scrape it across concrete, but make it really loud and happen 3 times within a second). this doesnt happen all the time tho, we only go the noise to happen once we did as stated above. under normal driving conditions when hitting WOT nothing happens. he origionally thought it was a misfire but i doesnt sound anything like a misfire that i have ever heard. the only other thing abnormal about his car was his tail pipes were much blacker than normal..... any ideas? thanks for any and all help
Old 05-10-2006, 11:02 PM
waiting2bl33d's Avatar
it sounds like knock. what kind of gas is he running? has he always used the same gas station? (does it sound like a spray paint can when you shake it best way to discribe it)
Old 05-10-2006, 11:07 PM
stanger96's Avatar
well i dont know if he has an exclusive gastation but i know he always puts 93 octane. yea i guess u can say it sounds like that
Old 05-11-2006, 01:19 AM
staringback05's Avatar
some stations have been known in the past to have water in there gas.....cone, and another one i cant think of right now....but of course thats not really good for a car
Old 05-11-2006, 09:26 AM
stanger96's Avatar
do u think its just a bad batch of gas?
i did also forget to mention that this isnt his daily driver, so it does sit often....
also it comes from the drivers side in the engine bay somewhere....
he wants to bring it to the mechanic, but he'd like to have and idea on what it might be first, just in case it doesnt make the noise when hes with the mechanic
Old 05-11-2006, 12:06 PM
could be a bearing problem if you cant really hear it wot. on low rpms the bearings will wobble...lol well i just gave u both ends of the spectrum....bad gas...and bearings
Old 05-11-2006, 01:46 PM
stanger96's Avatar
well the thing is u can only hear it at WOT but only if you punch it from when your slowing down we have found, cuz when he tryed to recreate the noise for us it wouldnt do it during regular accel. only if you were slowing down to almost a stop then punched it ud hear it right around 5k
Old 05-11-2006, 10:04 PM
stanger96's Avatar
..ttt..
Old 05-12-2006, 09:33 AM
has he done any work on recently. exhaust or maybe plugs?
Old 05-12-2006, 10:36 AM
stanger96's Avatar
no not recently....he does have exhaust (~2yrs old) intake (2years old) plugs (~2 years old)...
Old 05-12-2006, 01:51 PM
stanger96's Avatar
do u htink it could possibly be the optispark?
Old 05-13-2006, 10:37 AM
stanger96's Avatar
...ttt...
Old 05-13-2006, 05:08 PM
jbird's Avatar
I don't think it would be the optispark, but you never know, anything can happen with them. It sounds to me more like a mild exhaust leak that is muffled by the other noises of the car until you're WOT. The air fitting on the driver's side manifold of my formula came loose and did the same thing. It was completely off the manifold and I could barely hear it at idle if I opened the hood, but at WOT it sounded like the car was going to fall apart. It could also be bearing or spark knock. How many miles are on the car and what's the oil pressure like. I had one opti cause spark knock, but it was nearly all the time, the car was overheating and generally didn't run well. All the other opti failures I've had were just a high rpm miss that gradually grew worse, then a couple of weeks later the car would just start dying. A lean condition could also cause spark knock, maybe the fuel pump isn't supplying enough fuel at wot/high rpm. Anyways my bet is on an exhaust leak somewhere.
Old 05-14-2006, 10:53 AM
stanger96's Avatar
cool thanks
not to sure what the oil pressure is like but he has 90+k on the motor....if the air fitting on the header was just loose would it only make the noise sometimes then ?
Old 05-14-2006, 11:28 AM
jbird's Avatar
No, it would make noise all the time. Whether or not it would be loud enough to hear over the car running all the time is a different story. I have no cat and a flowmaster only and I couldn't hear mine except at WOT.
