pulling TA turn signal housings
Old 05-13-2006, 11:19 PM
flyin red TA's Avatar
Default pulling TA turn signal housings
I have a 98 TA, both front turn signal housings are loaded with water. I need to get them out so I can tell if they're cracked or not sealed right somewhere.
Should I attack this from the top or the bottom? I searched around and didn't find any recommendations for pulling the whole housing, just the bulbs. Top or bottom doesn't matter...I just don't want to attempt it one way and find out I can't get them out.
Old 05-13-2006, 11:43 PM
12Gauge's Avatar
I went in through the bottom to remove the screws then removed the plastic around the headlights to remove the housings from the top.
Old 05-14-2006, 04:43 PM
Pewterpower's Avatar
You can get the whole thing from the bottom. It's awkward, but it's just a couple 100mm (I think) screws.
Old 05-14-2006, 07:24 PM
2 10mm screws holding the cover, then 2 7 or 8mm screws holding the housing...I did it all through the bottom and it sucked.
Well it wasn't really that bad, but orange water pissed all over my head as soon as I pulled the bulb.
Old 05-14-2006, 09:22 PM
Did I say 100mm? That's a helluva bolt!!!
Old 05-16-2006, 09:17 AM
LS69TA's Avatar
I just did mine. 7mm bolts. I broke one if mine putting the new ones back in
Old 05-16-2006, 05:28 PM
04goatinmass's Avatar
anyone know where to get a replacement lens for this.i have a v6 bird and my housing is round.its seems tough to get at even just to change a bulb.also i cant realy see the inside .do u mean 10mm socket ?and pics of what one looks like and wher ethe screws are located to remove the housing?
