Does tack-welding on axle tube result in an internal axle fire?
Old 05-15-2006, 11:42 PM
Studytime's Avatar
Default Does tack-welding on axle tube result in an internal axle fire?
I need to adjust the angle of my rear anti-sway bar, and it's going to require welding on the axle tubes of my car. I'm a little worried about welding on it with oil in the tubes. Am I just being paranoid? Is there a chance I could start a fire within the axle tube?
Ben T.
Old 05-16-2006, 07:40 PM
2002_Z28_Six_Speed's Avatar
I wouldn't think so. If you got the oil really hot it could start smoking and maybe catch fire but that would take a long time. Much longer than it takes to tack weld something.
Old 05-17-2006, 01:20 AM
KingRuger's Avatar
no, you will be fine
Old 05-17-2006, 07:38 AM
2manytoys's Avatar
Generally oil won't burn unless it get really, really hot and is exposed to open air. So you should be fine.
Old 05-17-2006, 05:28 PM
Pewterpower's Avatar
People get thier axle tubes welded all the time......
