Door rattles just won't go away
After reading many other posts and replacing parts per their recommendation, I still have an annoying rattle sounding like the glass is going to break. It only rattles when more than half way down, never when all the way up or when the glass touches the weatherstrip. So far I replaced:
Outer door seal
Window stabilizers
Door latch
Lubed the window tracks and gear
I also checked the rivets they seem nice and tight. The rattle seems to happen if I close it harder. It will also happen if the passenger window is open and the driver window fully closed, and I shut the driver door hard enough. Any ideas? Thanks
Outer door seal
Window stabilizers
Door latch
I don't think it's the glass since when down, it looks like it rattles just as much as the passenger side, but the passenger door does not make that noise. The glass is seated nicely along the weatherstrip, and the window does not leak. What else should I be looking at besides the glass? Or should I just live with it? Does anyone else experience this when they shut the door hard?
My window used to rattle a lot when rolled down more than half way so I finally had an idea an it worked...
The window brackets I guess you could call them that (the 2 metal brackets with carpet on them, on top of the door under the stripping) well they are adjustable... so I just rolled down my window were I had the most play, pushed the bracket up to the window and tightened it down.
See if that helps..?
I just had my passenger window replaced the other day. It still rattles but not as much as it did before. I adjusted the stabilizers when it was up so I'm going to try to do it where it rattles the most. Hopefully it works
